HiFlight
Just enjoy your music and Play Store functionality.After updating to the Lurker FW is (are) there anything I have to do or just enjoy my musics?
It only disconnect when the screen is powered off. You will need to put the screen to be always on. If only @Paul - iBasso would ask the software team to allow the screen to be continuously on in DAC-USB modeCan't use dx200 as USB-DAC on windows 7 or 10 - it disconnects after few minutes and needs to be reconnected. :/
Well that's not so healthy for the battery, lcd and other electronic components (more warmth radiating)...It only disconnect when the screen is powered off. You will need to put the screen to be always on. If only @Paul - iBasso would ask the software team to allow the screen to be continuously on in DAC-USB mode
Well, or having the screen off without this feature turned off. The previous firmwares had auto triggers, it kept the screen always onWell that's not so healthy for the battery, lcd and other electronic components (more warmth radiating)...
Actually since 30 minutes it's working fine - I switched the screen off manually and didn't let it go off by itself. Maybe it will work this way. :>Well, or having the screen off without this feature turned off. The previous firmwares had auto triggers, it kept the screen always on
nice discovery lol. Now if @Paul - iBasso can tell me whether amp6 work on dx200 or notActually since 30 minutes it's working fine - I switched the screen off manually and didn't let it go off by itself. Maybe it will work this way. :>
If you run my firmware build, I'd suggest to try to turn on USB DAC function from the menu of USB Audio application.Can't use dx200 as USB-DAC on windows 7 or 10 - it disconnects after few minutes and needs to be reconnected. :/
I says right on iBasso website that all of the amps are interchangeable between both DX200 and DX150.nice discovery lol. Now if @Paul - iBasso can tell me whether amp6 work on dx200 or not
Also, I would like to know about DX200 limited edition ?
Do they make that in a 4.4 to 3.5SE to use with my paw gold?
Here you go!
I'm an old (still wonderful DAP!) DX90 user, so please forgive my ignorance, but the factory reset is done through the menu options "Back & Reset" - " Factory data reset"?
