Hey
Actually I would like to know the differences between the two as well please. . . . I just got a new DX200 (my first one had the faulty touchscreen), so I have to start over with ROM installments. . . Do any of your ROMS allow for improve sound quality (or third party app access) with TIDAL? That is the prominent app that I use outside of the music stored on my DX200.
Also Lurker on your mod page you have this statement for USB Audio:
If you want more than one USB Audio compatible music player, use Active player feature to avoid problems.
Can you please explain where this "Active Player" feature would be located? If I go with your ROM, I'll most likely have both UAPP and Hiby downloaded on my device (again because of TIDAL access)
Any help is greatly appreciated!!
I am not the best one who can answer 100% correct. But based on my opinion.
1. Difference about these two FWs: Actually I don't understand what they argue in Modded ROM Thread since I'm not a programmer. But IMO..
Lurker0 FW usually comes to create nice add-on like USB Audio to make user be able to play native sampling rate in Third Party app, and he also fixes iBasso' s latest bug that Battery indicator percentage is missing. However USB Audio still have a bug while playing 44.1 kHz songs, it creates random tiny white noise which you can hear if the song is quiet and slow.
While Win X states that he find ways to code it for sound quality enhancement in his FW. I don't know if enhancement is the right term but I can feel it does have different in Sound signature in Free ROM compared to Stock one. (Actually Lurker's as well) However in latest ROM, he tries to reduce CPU core to 1 core for battery saving, It does cause player to reboot itself when the screen is off for a period of time.
Note: I didn't say their FW's sound quality are changed in positive or negative terms. Try by yourself is best way. It might be time-consuming at first but you will then have a clear mindset whether you will go to which rom. Totally worth time spent, I believe.
2. If you want to use Tidal, you can use it freely in Tidal App if you are into 44.1 KHz lossless CD quality since 44.1 kHz is the native sampling rate for third party app.
But if you want to play MQA natively then you need Lurker FW and use it along with UAPP. In UAPP, you can access to Tidal and play MQA file natively thanks to USB App
3. I believe "Active Player" in Lurker's term means any player you are running at that time.
