That's great, Paul! So, Mango app will not downsample, and of course in Mango OS mode nothing is downsampled either! What is a meaning of "SRC off" button in your Mango player? I mean, it looks like it's not enabled, maybe will be enabled in the future update. But what does it toggle?
See post 3196. Currently SRC is not functional but will be enabled via firmware update at some time in the future to work with other apps. (according to iBasso) It is used to toggle different sample rates.
I know, you said "SRC is currently nonfunctional but will be implemented in a future firmware update." while Paul suggested "The DX200 does not downsample in Android or Mango." To me, nonfunctional means SRC is enabled and audio will be downsampled, while it contradicts what Paul is saying. Besides, Mango android app also says "SRC off" meaning sample rate conversion to downsample the audio is OFF.
You guys find the UI... Different? I loaded songs up, but had to go through the menus to get it to play. Also, when in now playing I had the options stuck on that screen, couldn't figure out how to get them off. Had to reboot.
Plus, I have to reformat an SD card to get it to play, and it only plays with this device? Is that accurate?
Listening to it now as I walk, great sounding player. Briefly had my isine20s, seemed like an excellent match.
When you configure your card, you have the option to make it specific to the DX200 or not. Once you choose the option to format it for the DX200, you no longer are able to use that card in other devices.
Really? OK. Good, I didn't see that option. I only had 2 cards with me, one I'm not reformatting, the other I tried. It said it was corrupt and the format failed. I have to find my other 200gb card... It's lost somewhere in the black hole, also known as my bedroom. Fortunately there is internal memory to hold me over.
