DX200=Affordable High End Audio. Dual ES9028Pro dacs. AMP1, AMP3, AMP5, AMP7 & AMP8 ***Firmware support now up for AMP9***
Discussion in 'Portable Source Gear' started by paul - ibasso, Dec 17, 2015.
  1. ropie
    Ibasso battery 15 euro, shipping to NL 10 euro
    Swapping battery piece of cake.
    It's the same battery as the DX220 has
    Carlsan likes this.
  2. krakenkr
    Hey, where can it be ordered from? Thanks
  3. immortalsoul
    Here is the message that I got from Paul
    Hello,
    You can purchase the battery from us by using order@ibasso.com and using PayPal. The battery is 15 USD. You can also have John at jamato8@yahoo.com change the battery for you as he is in the US. The payment for the battery goes to us and he just charges for the shipping back to you.
    Best regards,
    Paul
  4. krakenkr
    Thanks a lot for your help!
  5. ostewart
    Is there still a consensus that Mango mode sounds better than Android mode?
    I pretty much only use mine in Android mode
    Rayzilla likes this.
  6. Rayzilla
    I think I am due for an update but I've never had to do any kind of firmware update before other than the automatic mobile phone updates. :jecklinsmile:
    So I'm kind of afraid to. Here is where I am. What would I need to do? I'm on a MacBook.
  7. Whitigir
    I never had any problems with online updater
    Dobrescu George likes this.
  8. AnakChan Moderator
    If Rayzilla is coming from 2.10.215, I don’t honk online updater’s gonna work for him. Will need to flash to Oreo then online update after that.
    Whitigir likes this.
  9. Glasha
    I still prefer the Mango mode.
    ostewart and lantian like this.
  10. Whitigir
    Same here , unless you have Fidelizer :)
    ostewart likes this.
  11. netjohnston
    My DX200 is on Android 8.1 since updated Dec last year. I have downloaded the latest FW V1.06 and copied the ZIP file to the SD card.
    Tried to do local update but I got error message “Verifying failed, please check your package”. I downloaded the file again and still going
    nowhere with the same error message. Do not know what have I missed.
  12. singleended5863
    Does the DX200 have a local update now? I thought you can only update a new FW in DX220?
  13. Paul - iBasso
    Are you unzipping the file after you download it?
    iBasso Stay updated on iBasso at their sponsor page on Head-Fi.
    http://www.ibasso.com/
  14. netjohnston
    Paul,
    I did not unzip the file. All I have done was copying the file to the SD card and then used local update.
    Thanks for your quick response.
  15. netjohnston
    Go to Ibasso website and there are FW update files for each DX device.
