jamato8
Ah, going up in price and downgrading in sound.He is heading this way.
Depend on how you would take this route. Going R2R isn’t easy, especially R2R by nature is full of errors, these errors can be DSP and filtered, masked away. If it was done right then it can sound good but a tad colorful. People never dislike colored stuff anyways.Ah, going up in price and downgrading in sound.
To get the R2R to do better, it needs not only an excellent source with excellent power supply and ultra low low low ESR, Jitters in the 0.05Femto seconds and so on, it also needs many FPGA to help switching the arrays correctly to avoid these errors to downgrade the sound.
On paper, that HFM is not really impressive to me, while the idea is wild, I don’t look to adopt such at a price...by any times soon. The only company able to do this would be Sony, and they had let me down on the DMP-Z1
Yeah, I'm the one that wants to sell the DX200Ti to get the Hifiman R2R2000I thought he is going to get SP-1000M which costs $2.5K and I read somewhere that SP-100 has been received some not too good reviews?!
DX208 is one of the best DAPs out there. I've not heard the R6 but from my readings the DX200 w/ AMP8 will trounce it.
Stay updated on Forza AudioWorks at their sponsor profile on Head-Fi.
DX200 software update
have DL the latest, zipped up
start update
checking the package
verifying failed, check your package
have tried a different update version, same answer
any suggestions ?
tnx, yes, its in the root dir, same file name as you said.After downloading the DX200FW2.10.215OTA.zip file, where did you store it to? Did you try putting it under the root location of your SD card?
Then unzip it to have readme.txt and another zip-file. Then follow readme.txt.have DL the latest, zipped up
Could someone compare DX200Ti Amp1Ti to DX200 (no Ti) + Amp8 ?
Looking forward to the new lag-free Mango OS. Looks very responsive in this vid https://v.youku.com/v_show/id_XMzgxNDUyMTQ5Mg==.html?spm=a2h0j.11185381.listitem_page1.5!2~A
