DX200=Affordable High End Audio. Dual ES9028Pro dacs. AMP1, AMP3, AMP5, AMP7 & AMP8 ***Firmware support now up for AMP9***
- Thread starter Paul - iBasso
- Tags
- at8ie ibasso ibasso dx200
- May 7, 2017
Sony DMP-Z1
What about Cayin N8 or A&K SP-1000M?
hk29
RE: Upscaling to DSD512
What software are people using?
- Oct 14, 2013
Offline : XiveroRE: Upscaling to DSD512
On the fly: HQplayers or Foobar (free), Jriver. HQPlayer is better though
I still recommend offline conversion
- Oct 14, 2013
Neither one can do DSD512 Bwahahaha. Yeah, keep releasing new players, and it keeps exciting me on how much future proof the dx200 is ! Almost 2 years, no one could pull Dual es9028Pro with 7-8 hours of battery, and or Native DSD512 Roflmao.What about Cayin N8 or A&K SP-1000M?
Actually, let’s show people what we can do, dual ES4497EQ and or single ES9038Pro instead...oh, and while we are at it, let’s charge an arm and a leg for it.
- May 7, 2017
I have not tried DSD512 on either DX200TI and DX200 before and just love how my music‘s SQ is getting big improvement since I own them.
- Oct 14, 2013
Then you shouldI have not tried DSD512 on either DX200TI and DX200 before and just love how my music‘s SQ is getting big improvement since I own them.
- May 7, 2017
Then you should
How? Can you list step by step so I can follow? Thanks.
Ladies and gentelmen... I have been a DX200 user (AMP1) for a long time and was willing to switch to a used SP1000, WM1Z or Hugo2. Did any of you have a chance to compare the DX200ti to any of these devices?
Cheers
Cheers
Has anyone tried using a coaxial cable to connect with hugo? Coaxial doesn't seem to work and I am only able to connect using optical connection.
I am using Coax from my DX200 to Hugo. What's your source and do you have the right cable?
Jester0fTortuga
Did we ever figure out what the DX200 surprise was? A looming upgrade to Android 8?
I am using a coaxial cable like this. Works fine with other daps using coax output to hugo.
Not all cable works for all DAPs. For me, this is my dx200 coax cable to Hugo
PS : You can see some differences between your cable and mine. I suggest you go to audio shops Zeppelin at SLS or Stereo (i remember theres one at plaza sing) to try the right cable.
- Oct 14, 2013
There are 4 poles in your cables. Not sure how that works for other DAPS, but it is inappropriate . So, if you want a Coax, use a 2 poles or max of 3 poles such as this
Total: 9 (members: 0, guests: 9)
