AugustineNg
- Mar 27, 2016
It is to upgrade the shell app which the addon preinstalled to fully functionable appI'm on Oreo 8.1 with @Lurker0 1.09 add-on. It keeps asking me if I want to upgrade to the full version of Magisk and then asks for permission to access media files. Is this a paid upgrade and something I should do or will it mess things up?
AugustineNg
- Mar 27, 2016
I can't live without the DX200 for even a dayI sent mine back to ibasso after 15 months usage and it was returned to me with a new battery replacement costing 60+12 RMB. Given they are in shenzhen, i think its always a better option to back to ibasso
AugustineNg
- Mar 27, 2016
Believe me. There will be always not enough space for files. If you can afford it, directly go for the 512GB.Ok, I tried DSD512 and now I believe in God, the DSD God.
Can anyone post here some documentation that I need to play and make those files? I would like to use Foobar2000 to play them if possible. For now I'm playing them on my DX200
And I actually got some problems with my microSD
It's full
So now I have to decide if I want a 400 GB microSD or a way to use a hard drive maybe
Currently Im using and fully occupying the 256GB with files which was upgraded from 200GB, and it was also from a 128GB card.
But be reminded that the risk of losing everything on a SD card is considerably high, even for famous brands and their relatively expensive product lines, it is better to backup everything on a hard drive.
Lurker0
Magisk is open source and free. Initially, only a stub of Magisk Manager is installed. Most of users don't need it, and it is easy to render things to unusable just playing with it without understanding.I'm on Oreo 8.1 with @Lurker0 1.09 add-on. It keeps asking me if I want to upgrade to the full version of Magisk and then asks for permission to access media files. Is this a paid upgrade and something I should do or will it mess things up?
Magisk was removed from Play Market by Google, so this stub has implemented installation from its server. To download the full version, updates for Magisk core, modules etc., Magisk Manager needs write access to device storage, which, in turn, requires Android permission to access "media files".
Glasha
Yes indeed, I am going to do that today! Thank you for the advice!But be reminded that the risk of losing everything on a SD card is considerably high, even for famous brands and their relatively expensive product lines, it is better to backup everything on a hard drive.
And I didn't know about the 512 GB, wow! But for that price I can afford a HDD with a capacity of 4TB XD I just need a little HDD to carry with me maybe
marcuscmy
The player is able to side load apks right?
marcuscmy
I tried this once, the most annoying part about it was the UI for me, it was absolutely terrible, but I have heard people flash custom firmwares on them, how are they?
gazzington
To update the dap do you just copy the zip file to the root of SD card. And then update from there. Mine keeps failing
AugustineNg
- Mar 27, 2016
The 1uF MLCC as I was testing just by then, reduced the excitement and deepness of bass and strictly removed the sharp edges of vocals.I had the chance to take it up a notch. By replacing the TK from Ibasso with a beefier one 220uF/16V where as the stock one was 220uf/10V.
Anyways, I gotta say that I love the ultimately modified Amp8. The Amp8 is totally a beast. The angle of the picture wasn’t good enough, you may see the yellow cap touching the leg of the MLCC cap but it doesn’t and it should never
There is no need to replace your stock TK. I just did so because I could grab a couple of them
For those who wants to follow this mod. Here is a link
https://twister6.com/2016/09/09/amp8-diy-mod/
The reduction is beyond obvious, feeling like masked by mist, maybe a smaller capacitance MLCC can do it better.
Just simply changing the 220uF to 470uF had already made it a beast!
And I have searched a lot of places today to find the 4 100uF/16V capacitors for replacement as well but no luck.
I hope I can find 4 Nichicon Muse caps if I could get luck!
- Oct 14, 2013
Yes, you can go with 0.47uF if that 1uF is too much
This is Nichicon Audio series. The newest line UKA 100uF/16V
https://www.mouser.com/ProductDetail/647-UKA1C101MDD
I myself loved that Nippon
I just left my DX200 for a while, I really hate the reboot issue of the beta firmware. It is great that I have spare DAP...
- Oct 14, 2013
Turn it to Pure Mango, no reboot issues, just beautiful musicI just left my DX200 for a while, I really hate the reboot issue of the beta firmware. It is great that I have spare DAP...
Fernando Goñi
- Apr 28, 2017
I plan to buy a hd800s. Already have Amp8. I know that Whitigir is very happy with the combo. Any other experience? Which HP would you compare it against?
Flash Lurker add-on L-09. It solves.
- Aug 15, 2011
I've seen the tweaks here in this thread and in Twister6's blog and I understand what component values you're replacing and adding. However in terms of circuit-wise, may I please ask what are you tweaking? Is it the amount of negative feedback? Sorry if this was explained before in this thread nor in twister6's blog.Yes, you can go with 0.47uF if that 1uF is too much
Total: 18 (members: 0, guests: 18)
