DX200=Affordable High End Audio. Dual ES9028Pro dacs. AMP1, AMP3, AMP5, AMP7 & AMP8 ***Firmware support now up for AMP9***
Feb 12, 2019 at 2:36 PM Post #20,686 of 22,021
Ok I got the tutorial now. But for some reason I cannot get the device to be recognized when I push hold the Play button and connect to USB. Any ideas?
Did you install the driver for the PC and you could try another USB C cable if you have the driver installed. I have a couple of USB C cables that won't work for the update.
Feb 12, 2019 at 2:47 PM Post #20,688 of 22,021
Hi
Verify that your device is well turned off when you hold the play button.
Also post a screenshot it could help to understand...
Feb 13, 2019 at 2:01 AM Post #20,689 of 22,021
Do you guys have the AMP4 randomly powering off your DX200? Yes the DAP is fully charged. It's happened in in both Android mode (Lurker0-ed) and Mango mode. I've just switched back to AMP8 to see if I've regained stability in the DX200.
Edit: Scratch that. It's just happened to AMP8 too. Will try another amp module but suspect it'll happen to that too.
Feb 13, 2019 at 2:44 AM Post #20,690 of 22,021
Nope. I have been using the amp4s with DX200TI quite long time but never had such problems. Is your amp4 modded?
Feb 13, 2019 at 4:24 AM Post #20,691 of 22,021
Don't know. I got the AMP4 used. Having said that the iBasso sticker looks pretty well sealed/untouched.
Feb 13, 2019 at 2:19 PM Post #20,693 of 22,021
Guys,
I'm burn-in my AMP8 like the below image, so just using the Fiio 4.4to2.5mm adapter without any heaphones. Is it ok?
Thank you!
Feb 13, 2019 at 2:25 PM Post #20,695 of 22,021
Guys,
Thank you!
Per above, no load, no burn in. You need the burn in cable that came with the player. If you have a 2.5 TRRS output there with the adapter, then use the burn-in cable. Otherwise some headphones or IEMs at a normal listening volume.
Feb 13, 2019 at 4:28 PM Post #20,698 of 22,021
I see that a lot of people think AMP8 is better than stock AMP1. But does it worth extra $200 ?
Sure. I have the AMP4S and the difference is noticeable.
