W1ll1eTheP1mp
I have No clueSo, the modular ends, are they a solid one piece constructions ? Or are they Wired construction ? If they are wired, then what are those wires materials ?
thank you
thank you
I have No clue
The reason why I asked was because I recently bought one of the Top Of The Line Modular design and dissected it. It uses a very flimsy Litz copper of about 28-30awg sizesSo, the modular ends, are they a solid one piece constructions ? Or are they Wired construction ? If they are wired, then what are those wires materials ?
thank you
It's a good time to go #PRO. Our next generation of in-ears powered by ECLIPSƎ are here! Learn more on our official website.
Stay updated on DUNU at their sponsor profile on Head-Fi.
Perhaps you should give an options for 1 piece constructions. People who seeks for high end quality will want them for sure. You can supply it as your cable options and also DIY supply.Is that one of ours? The color on that anodize doesn't quite look like one of ours and the curve of the black plastic part is different --- going to assume it's from the company whose name is an acronym.
Irrespective of which company it's from, these plugs cannot be made in one piece because of how complex the locking mechanism is. They have to slide smoothly, lock, and be able to withstand 5000+ usage cycles. They also need to contain several shielding layers to prevent short circuits. Depending on the plating we use, the internal shielding structure is actually different because the way we plate palladium is very different from copper.
If we made these plugs in one piece for all four plug types, each plug would cost well over $100 (at mass production cost). Considering the fact that we already have many people concerned that our cables are "too expensive", making plugs in such a manner is simply... imprudent.
We have never considered the plugs to be 'superior' to an adapter in terms of signal transmission --- they should be on equal footing. We actually make adapter plugs ourselves. However, our modular cable system is smaller and more robust than most adapters, with fewer points of potential failure. Most importantly, almost everyone we've encountered have mentioned that they're more convenient to use.
There are some individuals who have commented that the plugs are too bulky. Most of these individuals have not touched or used our cables before. We've performed size comparisons against alternative systems, and they're comparable in size.
Hey! Do someone know where i can buy the connector? Or a connector that will fit the modular system?
Thank you for taking the time to translate this nice video. Keep up the good work Dunu team! I can see now that my Blanche will likely outlast me!![]()
Hello,
Are there straight modular plugs for Dunu cables? I have DUW02 and love it, but I would love it more with straight plugs![]()
We are sorry about your experience. We will provide the assistance you need to justify your experience. May we know which dealer you're buying from? We can step in to talk to them and find out what's happening with your purchase.Just awful buying service from an authorized dealer. I bought a cable Dunu Blanche, waited for 10 days to be sent, as a result, I received a message that my cable did not go to the transport company, now there is still a refund procedure, since the desire to buy has disappeared.
Did you bought from Penon? I had a similar experience, it was awfulJust awful buying service from an authorized dealer. I bought a cable Dunu Blanche, waited for 10 days to be sent, as a result, I received a message that my cable did not go to the transport company, now there is still a refund procedure, since the desire to buy has disappeared.
Thank you, I opened a dispute and it seems that it has already decided in my favor. Seller Beteran audio store AliExpressWe are sorry about your experience. We will provide the assistance you need to justify your experience. May we know which dealer you're buying from? We can step in to talk to them and find out what's happening with your purchase.
Again, we apologize for the inconvenience. Now we know the dealer, we will definitely look into the problem and provide further guidelines.Thank you, I opened a dispute and it seems that it has already decided in my favor. Seller Beteran audio store AliExpress
