- May 11, 2009
I defiitely recommed cryo'd tubes.
Gosh! this hobby is becoming increasingly ridiculous. What's next?? thousand pounds power cords? Cryoed fuse? Lutetium interconnect?
back on topic.
got my Sonett yesterday. it's a beauty.
What kind of tubes you are using with Sonett? It does not sound remotely to the one I got and I did audition with RWA HPA before.
I would not say a big difference but it is a noticeable difference. Try to get your hand on a Mullard GZ34 too, much better than the JJ one.
There isn't much choice on the driver tubes, I only tried the stock and DR. On the rectifier tube, I have tried Mullard GZ34, metal based GZ34, Sophia Princess 274B, EML 274B, and EML 5U4G mesh. Out of all of them, the Mullard GZ34 deliver the best bang for buck. Becareful with Sophia Princess 274B, EML 274B, and EML 5U4G mesh, they work but not recommended by Donal.
I had the chance too compare the Sonett against my RWA Isabellina HPA.
I used this setup:
Netbook -> USB -> Isabellina -> Sonett
So both used the same source, but the sound was very different. The Sonett sounded like the Isabellina but on some heavy drugs, added distortion and EQ. The Sonett sounded anything but clear and neutral. The bass sounded louder at some stages, the tweeter had much distortion and the sound overall was very very very warm. It sounded more like some kind of DSP than a amp. Both the Isabellina and my netbooks built-in soundcard gives you the feeling that the sound is pure and nothing is added, but on the Sonett, a lot of things where added.
Headphones used: HD800 and Alessandro MS-PRO
I can understand that some people might like/prefer the Sonett, as it sounds "different". Just like the ones that uses PS1 as a CD-player.
I can also add that I didn't like my Isabellina better because I owned it, I actually wanted the Sonett to sound better. And I have a friend that also had a go on the same setup, and he also preferd the RWA.
Don't really know. Probably stock, as it was in a store I tested it.
