What you guys thinks about those shells? looks good!
https://www.aliexpress.com/item/33013205678.html
So guys I guess I asked this before as well but did not get any response so does k's k600 sounds exactly similar to Beryllium 600 ohm drivers
or is there a difference
How did you @DBaldock9 tune itI also have those diy 400 and 600 ohm, my expectations were too high because of the price, after arriving they sounded good but not spetacular and I was a bit disappointed. I need to try to tune them and see if I can get them closer to my taste.
I tuned the 400 to have a lot more detail, by cutting the paper filter and opening some of the holes in the drivers back. I use the mx500 shell from k64, because the mx500 shell sold with the drivers is different inside and I don't like the sound image, i couldn't locate voice or instruments precisely.
After some days experimenting with the paper and opening the vents, I got a brighter sound, with much more detail, but also a lot of punch, the only trade off is that it can be a bit more tiring to some. After a lot of burnin it's one of my favorites in zishan z2 with acoustic music, voices, bossa nova and jazz.
The 600 version as it arrived is a lot different, warmer, more bass, more difficult to drive. It sounded better in zishan dsd than in z2.
It took a lot of time to tune the 400 ohm to the z2, music type and my personal preference, so I think I'll need to invest some time to try to tune the 600 model.
I want to put the 600 in a mx500 shell with mmcx connectors, but when I did that, I lost the wire venting port and they sound worst.
I went and open the port next to the wire, only to learn I made a very big hole (1mm) and bass was uncontrolled. One side had a smaller hole and sounded good, the othe was just a tiny bigger and bass was uncontrolled there. It's going to be difficult to make same size and tune the right size. I also tried some dampning materials inside without good results.
I closed those holes and start playng with the driver paper venting ports. I didn't had time to finish it and tune to my linking, it's still a work in progress, as I think they are also promissing.
This reflects my personal preferences, music type and my dap, others will get different experience, but it's worth sharing.
Hi, I'm looking for a android wire cable for my phillips earbuds. Could anyone recommend one? I'd like one that is 1.5 to 1.8m in length.
I've bought, and cut the 2.5mm plugs off of some of these cables, to solder the wires onto several earbuds.
The controls work well with my LG V30 Android phone.
(NOTE: Removing some of the clear outer sleeving from the wires, so they can be soldered to the drivers, is a bit tricky.)
https://www.aliexpress.com/item/32834725227.html
So, as promised, here are my quick impressions of these drivers.Look what I finally received today
I measured them all at 77 ohm (almost 78), which is the right value claimed.
I remarked that it is also real 15mm, so it does not fit 15.4mm classic MX500 shells, but they almost fit Yuin shells with their 14.8mm (I guess I will fix them with some very slight glue)
I will try to do that tonight, as I can't resist how is the sound provided by these drivers!
'laters
Not sure if I understood correctly but do you mean that my quoted above "15.4mm beryllium (130 ohm) drivers" are not interesting? do you have them? do they sound bad?I have not look interesting. I am really liking these: £10.55 10%OFF | 15.4mm speaker unit about 35ohms PET film Elastic bass 2pcs https://s.click.aliexpress.com/e/bXmCW6FQ
my experiments will continue, even electronic tinkeringSo, as promised, here are my quick impressions of these drivers.
I tried many shells tips, but unfortunately I don't recommend them at all. They sound dull and veiled overall. While the soundstage is large enough end enjoyable, this is more a mid-centric driver before all. Lacking details, and average bass (almost no subbass). Highs are very softened, so it is good for long period listening.
I decided to remove them and put my still best red film PK1 drivers which are MUCH better in every area. I did some new tuning with new cottons and holes into my yuin shells. They are definitely now my best Yuin mod so far. Will take some pictures soon, I moved from black to white shells recently. They looks very good with their custom copper cable (same cable as Blox YIN/TM9) from Thailand.
Thanks for the discover, I will grab a pair of your recommended 15.4 PET film drivers. I stay you tuned
