DIY Earbuds
53 54 55 56 57 58 59 60 61 62
64 65 66 67 68 69 70 71 72 73
  1. DBaldock9
    I just spent the night enjoying music (dozing on & off in my recliner), using my version of the DIY Beryllium 600Ω Earbuds -
    Merlin-PT, golov17, Rhino73 and 5 others like this.
  2. subwoof3r
    Where did you guys got these beryllium drivers, any link to share please? Looks interesting
    Cheers
    DBaldock9 likes this.
  3. chrislawrence
    I ordered them from Chitty's store. But it's not the only Aliexpress source: https://www.aliexpress.com/item/32910917383.html
    Rhino73 and subwoof3r like this.
  4. DBaldock9
    Mine came from Chitty's Store, as well.
    Their sound is really quite special.
    To me, they're a bit like a cross between the K's K600 and the Smabat ST-10.
    (Off-Topic - I've ordered a set of 10mm Beryllium drivers, and some Cherry wood housings w/MMCX, to assemble some new $78.38 earphones.)
  5. chrislawrence
    You mean these ones, David: https://www.aliexpress.com/item/32766220304.html?
    Keep us posted! If they are those, I had my eye on those very drivers as well. I was unsure how to mount them as an earbud though; it seems most of the 10mm driver shells are more on the lines of an IEM casing, such as this one: https://www.aliexpress.com/item/32507926085.html. Still, I'm looking forward to hearing how they come out; I'm currently building a CIEM using Knowles BA drivers; a dynamic IEM would be amazing!
  6. DBaldock9
    Yes, that's the driver.
    I contacted the seller (as noted in the description of the driver), and asked if it would fit & sound good in this housing - https://www.aliexpress.com/item/10mm-earphone-shell-Cherry-wood-mmcx-pin-pluggable/32787946986.html
    They said "Yes", so I ordered the drivers & housings.
    Rhino73, subwoof3r and chrislawrence like this.
  7. chrislawrence
    It seems Chitty is also stocking 10mm biocellulose drivers: https://www.aliexpress.com/item/32765713539.html They're expensive, but I'm considering taking the plunge. Not sure how they would compare to the beryllium drivers though. Any thoughts?
  8. DBaldock9
    I know that @HungryPanda has assembled some earbuds, or earphones, using some biocellulose drivers - but I haven't tried any yet.
    subwoof3r likes this.
  9. subwoof3r
    How can I resist to click the buy button when quoting such references?!! :D
    I will buy one pair tonight
    Thanks guys :)
    Always happy dealing with Chitty's store, just received my 3 pairs of white Yuin shells, they have been incredibly well packaged for just basic shells, very appreciated.
    HungryPanda and DBaldock9 like this.
  10. HungryPanda
    In my last batch of items from Chitty's store there were a pair tiny iems with 6mm drivers already in the front part of shell, cabled them up and glued together, the sound pretty good (a very interesting freebie)
  11. Jsingh4
    Where can I get these shells ?
  12. subwoof3r
    I finally decided to not buy the beryllium drivers and buy instead the "15mm speaker unit 78ohms" too, and another pair of new 150 ohms 15.4mm drivers.
    Can't wait to receive them :D
    DBaldock9 and HungryPanda like this.
  13. seanc6441
    Very sorry my post was misleading. This is the K's Black Ling. Not a diy earbud. So i don't know if you can buy this shell type separately. I wish it was sold for diy projects because it has a perfect fit with thin foams, as comfortable as pk shell but more weighty.
    There is however something similar like this
    https://www.aliexpress.com/item/-/32979868884.html
    Rhino73, DBaldock9 and subwoof3r like this.
  14. HungryPanda
    Yes I have 2 pairs of those shells wating for a nice set of drivers
  15. DBaldock9
    If you weren't across the ocean, with the correspondingly high mailing costs, I'd send you my set to try, so you can see how good the 600-Ohm Beryllium drivers sound. :ksc75smile:
    HungryPanda likes this.
