DIY Cable Questions and Comments Thread
Aug 22, 2021 at 11:40 AM Post #10,173 of 10,185
Aye75
Can anyone recommend a good quality silver wire to make a headphone cable that doesn't cost an arm and a leg pleaswe?
probably you could try - https://www.partsconnexion.com/DUELUND-81389.html
it's currently at 50%. Only drawback imho is it's a solid core which may make the final product a bit stiff. But I used this before for IEM cable and still acceptable depending on your design. To keep the cost low, I mixed it with copper.
Aug 22, 2021 at 2:59 PM Post #10,174 of 10,185
HiGHFLYiN9
Member of the Trade: Zynsonix
East Coast
Solid core wire can eventually break over time if it's bent in the same place (think of a copper hanger, just very thin). It's perfectly suitable for hook up wire and interconnects/speaker wire that isn't being moved frequently, but I wouldn't personally use it for headphone cables. Stranded silver is usually 7 strands, so if one broke it's not going to cause intermittent continuance. Obviously you are welcome to do whatever you like, I'm just trying to prevent an expensive loss.
Aug 22, 2021 at 7:36 PM Post #10,175 of 10,185
Aye75
Great advice. I haven't been using the cables mentioned for too long hence not to sure of the durability. thanks for your input.
Sep 19, 2021 at 8:27 PM Post #10,178 of 10,185
HiGHFLYiN9
East Coast
can nayone point me to a person who can re terminate a headphone cable from 1/4 amp end termination to a XLR 4 pin termination? is this even do able?
It depends. If there are four wires in the cable (a positive and negative going to each each earcup) then no problem. If there are three, you need to replace the cable for balanced. If the cable is aftermarket like one of mine, it will come with 4 wires. If it's stock, there is a good chance it has three wires as that is cheaper to make.
Which headphone/cable is it?
Sep 24, 2021 at 9:22 PM Post #10,180 of 10,185
gruedude
Minnesota
I'm interested in making a female 4 pin xlr to banana plugs cable but I'm a total noob at this. Do I just connect the left + pin from the xlr to the wire running to the left + banana plug, the left - pin to the left - banana, and so on and so forth?
Sep 25, 2021 at 10:34 AM Post #10,181 of 10,185
TrollDragon
Windsor, NS
Yes. I assume you are hooking this to a speaker amplifier so you want to make sure you keep all the +/- separate (a pair of wires going to each cup). Most power amplifiers do not share a common ground on the speaker posts, so I would check that with an ohm meter before you try plugging any single ended headphones to your cable.
With the power off and amp unplugged measure the resistance between the left and right speaker - posts, if it's close to 0 ohms then you are good to use single ended connections (L+, R+ and a common -) with your amp. If it measure much higher then never bridge the posts.
Sep 28, 2021 at 4:47 AM Post #10,183 of 10,185
doctorjuggles
Member of the Trade: Cable Builder
London, UK
Is there a good right angle 4.4mm connector? I tried the ones from QYFANG and they were kind of bad with poor fitting.
Sorry, ignore me. Read this incorrectly
Oct 15, 2021 at 1:30 AM Post #10,184 of 10,185
mauiatheart
Hawaii
Planning on putting together my first set of headphone cables. Kind of nervous. Trying to get the biggest list of things to avoid so I don't screw anything up. Looking through this topic is a little daunting with 679 pages. Is there anyone who can summarize the things to try to avoid doing?
Oct 15, 2021 at 9:08 AM Post #10,185 of 10,185
Chuck Dee
Member of the Trade: Chris Cables
Make sure you PLAN the build process.
i.e make sure you have placed connector housings, pieces of heatshrink etc on the cables to be terminated before you start soldering.
There's nothing worse than realising you made a nice neat termination of a 4 pole miniXLR and realsing you forget to place the rear part of the shell on the cable before doing so. Ask me how I know this. I'll never get that time back. :blush:
Also, when it comes to cable -measure twice, cut once.
Always be testing for continuity when progressing through connectors with multiple terminations, XLR's, DIN plugs etc.
Don't be afraid to canvas advice from the forum if you get stuck!
Good luck. :thumbsup:
