DIY Cable Questions and Comments Thread
Nov 5, 2021 at 11:20 AM Post #10,202 of 10,204
supadupaninja
Germany
Nov 5, 2021 at 12:06 PM Post #10,203 of 10,204
TrollDragon
Windsor, NS
Hello guys,
I want mod my DT1990 to balanced.
Is there any common standard for the Mini XLR or can I use the one from the normal XLR like described here?
http://www.diyaudioblog.com/2016/02/headphone-connectors-pins-pinouts-for.html?m=1
Pin 1 - L+
Pin 2 - L-
Pin 3- R+
Pin 4 - R-
I don't think there is a configuration standard for single sided audio 4 pin mini XLR. When it comes to dual mini 4 pin most people use the Audeze configuration.
The configuration you have chosen would work fine since you are making your own cable. You will also have to modify the DT1990s internal wiring to support balanced and match that connector.
