DIY Cable Questions and Comments Thread
Apr 10, 2021 at 11:43 PM Post #10,066 of 10,535
Quick question, I'm making an cable replacement for the Focal Celestee (3.5mm mono — same as Stellia, Clear, etc...). However, I only have 3.5mm stereo TRS jacks rather than the TS jacks that Focal ships with their cables.
I figured the tip would be hot and the sleeve would be negative/ground? Or is it sleeve and ring? Or just ring? 😮
For the headphone ends you can use TRS plugs as good quality monos are hard to find. The tip as hot and the sleeve as common neg/ground. I did this for my focal clear professionals just recently. Check out this pic.
Apr 10, 2021 at 11:44 PM Post #10,067 of 10,535
Just strip the ground/negative back further, solder to the S then take it over and solder to the R too. Basically easy way to bridge the R and S together, ensires it'll work with all 3.5mm headphones, some random models use the R as the ground....
Apr 11, 2021 at 3:57 AM Post #10,068 of 10,535
I use Cardas on everything now, no issues whatsoever soldering to the rhodium plated Furutech. Can get the Cardas flux paste too, flux that baby right up.
Quad Cardas is eutectic so it'll stick on anything with flux and heat but they refuse to document the % of silver and it comes with a low melting point so IACS conductivity is most likely very very poor.
Apr 11, 2021 at 4:20 AM Post #10,069 of 10,535
Very very poor hey. Strong words.
Apr 11, 2021 at 8:12 AM Post #10,070 of 10,535
I think you're worrying about a bunch of nothing. The electronics you're using upstream are all soldered together, more than likely with lead-free SAC305, is that somehow not conductive enough for you?
Apr 11, 2021 at 10:11 AM Post #10,071 of 10,535
Cardas refuse to document the exact mix of their quad solder, silver % is most likely very low considering the low melting point so yes, expect 5-10% IACS or so: https://doc.xdevs.com/docs/_Materials/Chemistry/solder_alloy_directory_brochure_97720_r2.pdf
Copper is 100% IACS for that matter: https://www.bluesea.com/resources/108/Electrical_Conductivity_of_Materials/
I'll go screw-in for the RCA sockets, that'll also save from pesky soldering on rhodium plating :)
14% IACS isn't too bad: https://www.telametal.com/en/cproduct/sac305-fil-soudure/
Apr 11, 2021 at 1:41 PM Post #10,072 of 10,535
Thank you both!
Apr 11, 2021 at 5:29 PM Post #10,073 of 10,535
Guess the cheap arse poor Cardas or 60/40 solder hooking up all the internal wiring is very very poor too. Real strange to use it. In all high end electronics and all high end cables. Real odd.
Apr 13, 2021 at 9:55 PM Post #10,074 of 10,535
Haha. Moon audio uses FedEx. Whatever they do, it comes USA to Australia in a week, no customs etc on top. Might be different in UK.
Then USPS I'd be lucky if it ever arrives. And Royal Mail just takes its Royal time. And its updates go silent for weeks and it suddenly arrives!
I ordered some Senn HD 800 connectors from Moon. I'm ~60 miles from them in NC, and it took 5 days.
Personally for me, anyone but FedEx.
Apr 17, 2021 at 3:59 AM Post #10,077 of 10,535
Hello! I need som guidance here:) I received a OEAudio's Multi-Plug yesterday that im planning to use it on one of my cables. All my cables is either 4 or 8 core. How do i find out which cable that is R+, R-, L+, L-? The multiplug looks like this:
Do i need to buy myself a multimeter?
Apr 17, 2021 at 4:15 AM Post #10,078 of 10,535
Yes, one with continuity functionaltiy...
Or...haha...
Track the cable from the connector alllll the way to the amp end plug haha.
Apr 17, 2021 at 4:26 PM Post #10,080 of 10,535
Not necessarily. Some cable testers have continuity function and are good for people who just want to work with cables. Cheap ones can be dangerous when you try using them in situations you should not and anyway multimeters can be overwhelming for people.
If you're gonna get into electronics, wait until you know more about what you want.
The Thomann cable tester has a continuity tester, comes with probes, and can help with many standard kinds of cables. Not headphone cables though except for 3,5mm and 1/4 inch.
https://www.thomann.de/intl/millenium_mct20.htm
