Benno1988
Balancedd cables has four (4) wires. Not 3.Since a balanced cable has three wires than does it mean that if I want a TRRS (L+L- and R+R-) then wouldnt changing the jack connector to a 2.5mm TRRS make the cable work on amp/dacs that require a 2.5mm TRRS input? Also how do i tell if the headphone cable is balanced other than looking at the jack itself?
Balanced cable, ignoring the amp end plug, will have 4 separate conductors, two to each cup. The negatives need to combine together down at the amp end plug and not weirdly further up in the Y split for you to be able to reterminate it to be balanced.
So four distinct and separate conductors / wires, from the cups to the amp end plug.
