DIY Cable Questions and Comments Thread
Feb 26, 2021 at 7:21 AM Post #9,964 of 10,589
Feb 26, 2021 at 7:49 AM Post #9,965 of 10,589
Feb 26, 2021 at 11:59 AM Post #9,967 of 10,589
Great, thanks! This is my first DIY attempt so I appreciate the feedback.
Initially I thought I'd need to just recable the 6-pin connector to change these from unbalanced to balanced. However, it appears that the cable between each set of cups has a shielded ground instead of separate wires.
  1. Can I use the existing shield as a wire in a balanced cable (i.e. use the shield for L- & R-) or would I need to recable this as well?
  2. Similiar question for the cups themselves, do I need to open up each side to check to make sure there are dedicated wires (instead of a ground wire) for L- & R-?
Here are some images, an existing (unbalanced) wiring diagram from Beyer, and a sketch of the new 6-pin balanced connection for reference.
You would have to see if they have the shield wires tied together in the cup with the 6 pin socket, which I assume that they do. It's just a matter of moving that (headband wire) shield wire to it's own pin on the 6 pin socket. Then wire up your 6 pin plug for balanced accordingly.
So many option with that 6 pin plug, you could pick up a second cable and wire it for SE so you wouldn't have to use a Balanced to SE adapter per se.
My T50RP are wired with dual 4 pin tinyXLRs, I use them on all my headphones. The left socket is wired so I can plug in a single sided cable for portable use if I don't want to run the long dual sided cable with an adapter.
Feb 26, 2021 at 12:08 PM Post #9,968 of 10,589
Thanks for the suggestions guys, these could work for me: https://www.amazon.com/Junction-Underground-Waterproof-Electrical-Connector/dp/B07PQDT4B8. 4 pin and accepts up to 12mm wire, though plastic its lightweight and still looks good.
Edit- sorry it should be like this one, one posted above is not like a snap on connector(the wires are screwed in a singular terminal). https://www.aliexpress.com/i/33035240376.html
Those are nasty looking and made for AC mains coupling. ;)
I'd look into the LEMO Redel line, they come in 4 to 22 connections and would be a better choice IMHO.
https://www.lemo.com/en/products/plastic-connector/redel-sp
Feb 26, 2021 at 12:14 PM Post #9,970 of 10,589
Not bad, but I have never ever figured out how to buy on their site :D
I don't think they sell to end users, you would have to get them from Mouser, Digikey, Alpine etc.
Feb 26, 2021 at 12:50 PM Post #9,971 of 10,589
I think I will go with a next combo for a balanced cable for HD600. I have Mogami Neglex 2534 cable that I will connect to XLR mini on one side and LEMO on the other side. Diameters should be just fine. On the other side of LEMO, I intend to use 2 Mogami 2901-00 Lavalier cable (it doesn't says it is balanced cable, I would like someone to confirm that) which will go to HD600 connectors.
Feb 26, 2021 at 3:05 PM Post #9,972 of 10,589
Those are nasty looking and made for AC mains coupling. :wink:
Yeah this is well and good also except for the cable diameter maxed at 7.5mm for all variants :( I need at least 8mm(I will be using a pair(4mm each) of van den hul d501 silver hybrid). Maybe I could squeeze it out but could not find one selling the 4 pin 7.5mm variant.
Feb 26, 2021 at 4:36 PM Post #9,973 of 10,589
Yeah this is well and good also except for the cable diameter maxed at 7.5mm for all variants :frowning2: I need at least 8mm(I will be using a pair(4mm each) of van den hul d501 silver hybrid). Maybe I could squeeze it out but could not find one selling the 4 pin 7.5mm variant.
Was just a thought. The manufacturers sites are full of great products, but impossible to find someone who actually sells them. Good luck on your search though.
Feb 26, 2021 at 6:34 PM Post #9,974 of 10,589
I hate YC-8. I am cable maker for keyboards and I pray that no one will ask for YC-8 connector. And YC-8 have too small hole for balanced 4 wired cable.
I would need to find something similar to YC-8 (maybe LEMO) that has big enough hole.
What makes you hate it? Was fine for me, and I'm using it in a balance configuration too as you can see above.
I have some other connectors on the way that I'm going to try out that has a larger opening, but the YC8 seems fine to me so far.
Feb 26, 2021 at 6:40 PM Post #9,975 of 10,589
Oof found some of those lemo connectors except with a 18 week lead time...lol
