DIY Cable Questions and Comments Thread
Feb 28, 2021 at 5:11 PM Post #9,992 of 10,589
The guy said he has enough experience soldering. I guess he is either working with some fake gold plating on counterfit connectors or is using unleaded solder for the first time, etc. So far what I am reading does not add up.
Feb 28, 2021 at 5:19 PM Post #9,994 of 10,589
They are furutech connectors so most likely rhodium which can be a bit finnicky from my understanding.
Ah this could be it I think the OP said they were gold plated.
Feb 28, 2021 at 5:24 PM Post #9,997 of 10,589
Said he would rather use cheap gold plated I believe. Either way, likely not hot enough or needs to rough it up a bit for best results.
Let's get ready to ruuuumble :D
Mar 1, 2021 at 6:56 AM Post #10,000 of 10,589
Mar 1, 2021 at 12:55 PM Post #10,001 of 10,589
@chezzer - they're more difficult than usual to solder
The Furutech website specifically mentions that a light sanding of the plating might be necessary (but don't go overboard because you could possibly file away into the copper alloy)
Source: http://www.furutech.com/2017/09/19/15555/ (it's mentioned under "Specifications")
Mar 1, 2021 at 1:01 PM Post #10,002 of 10,589
Thanks, that's a great help, the main culprit is the R+, the solder just seems to sit on the top and the layout of the connector is just ridiculous, every
other 6.35mm that I've soldered has wings, which is a perfect method, not sure why they had to approach it differently.
Anyway, much obliged.
Mar 1, 2021 at 1:09 PM Post #10,003 of 10,589
Sadly this is more and more common. I had the same issue with Neutrik 6,35mm plugs and RCA connectors recently. No ground lug.
The old days really were better.
