DIY Cable Questions and Comments Thread
Dec 22, 2019 at 12:58 PM Post #9,451 of 10,535
Dec 22, 2019 at 2:34 PM Post #9,453 of 10,535
Why don't you just cut the cable where the glue is and buy a new 3.5mm jack
That is exactly what I will do but as I wrote in my first post this will mean that I have no headphones until sometime in january. This is because I live up in the arctic and it takes quite a while to receive anything through the mail, especially now with the hollidays and all. That's why I made the effort to try a repair instead of just ordering a new cable.
Dec 23, 2019 at 11:47 AM Post #9,455 of 10,535
Unless it is too cold to snow :wink:
Dec 23, 2019 at 12:19 PM Post #9,457 of 10,535
I'm in Prague and we haven't had a decent snow in a few years. Still hoping!
Dec 24, 2019 at 7:37 AM Post #9,458 of 10,535
I probably would as it's a nice looking wire, if you buy from cosmic cables then you should talk to him, he is very helpful and he would
probably even send you the wire braided if you want but if this is the case you should probably go for 8 wires rather than 4, which
headphones are you making the wire for.
When i would go for 8 wires, this would mean 4 wires for each side of the headphones.
How do 4 wires (22AWG) fit into a headphone connector plug? Most of them are really tiny.
In my case i have to use this plugs:
https://furutechwebshop.nl/winkel/furutech-ft-2ps-f-rhodium/
The opening hole doesn't look very big...
Dec 24, 2019 at 8:18 AM Post #9,459 of 10,535
Dec 24, 2019 at 9:06 AM Post #9,460 of 10,535
That plug is only suitable for up to 3.5mm Cable Diameter, so fitting 4 22AWG wires in there will be though
Depending on your comfort level, you could ream out the aperture with a Dremel or a drill. But yeah, 4 22 AWG wires with the added bulk imposed by braiding them seem unlikely to go through those holes unmodified.
Dec 24, 2019 at 9:12 AM Post #9,461 of 10,535
Thanks.
Would you personally recommend to use only 2 wires per side (4 in total, instead of 8) or modify the plug somehow?
Dec 24, 2019 at 9:19 AM Post #9,463 of 10,535
Thanks.
Personally, I’m the kind of guy who will modify just about anything—I’ve got a pair of 64 Audio A18ts, and I modified those. And I like 8 wire braids better than 4. But my shopping has led me to believe that Furutech connectors are pretty expensive, and most people get by just fine with 4x22 AWG cables or thinner. It’s really about your own tolerance for risk to your raw materials.
Dec 24, 2019 at 9:28 AM Post #9,464 of 10,535
Why does it have to be the Furutech connector, there are others with much bigger entry hole
The connectors must fit to the Fostex TH900 MK2 headphones and the connector is a bit unique. They are similar to Sennheiser connectors but not the same, so you can't use Sennheiser plugs.
I know that these Furutech connectors fit, because they are made especially for the Fostex headphones. And i'm not aware of another connector that definitive fits and has a decent quality.
Or do you have an alternative suggestion for me?
