Hey guys, and gals and a Merry Christmas to you all!
Regarding the snow: I don't know if it's to cold to snow exactly, never heard that expression. It's around - 3 c at the moment. When it gets below - 20 c we usually say that it is guaranteed no mosquitoes outside. If it gets below -30 c, that is regarded as cold. Below - 40 c (yes, that happens) is known as "Flintstones" because some cheap care tires freeze and get flat spots at those low temperatures. So when you drive away it's like having log slices for tires just like the Flintstones. But we have no snow at sea level at the moment. If one is inclined to go skiing then just sling the skis on the shoulder and go behind the house and start up the mountain. Over 200 meters there is a lot of fresh powder snow. You better start early to catch the short window of daylight/twilight. The sun doesn't come above the horizon again util January. Today being Christmas eve means that we are at the turning point and the days are getting longer and longer. Tomorrow the day will be 3 seconds longer than today, they said on the news. I can't wait..
But enough of that.
I have been trying to read up on some cables, what is needed, what is best, different design and so forth. I have a small tip solder iron, I can borrow a multimeter if needed and I know the basics of soldering.
The cable making craft is enticing and also daunting and there is a lot of questions that present themselves from the get go;
Do I want silver wires?
Do I need silver wires?
What gauge?
Braided or paracord covered?
What size paracord?
What the heck is LITZ?
Do I need that?
What is a soldering pot? I don't think I want that.
Which connector suits the choosen setup?
Which splitter fits the setup?
Mmmmm, meh..
Have you been here? If so then you probably know the answer to many of these questions by now. You probably have a designated work space for this kind of job even. With shelves stacked full of dusty HI-FI skeletons and wire barrels, sine wave generator, power supplies. Luxo enlarger desktop lamp, table and carpet peppered with solder burns. Tray cabinets with connectors, splitters, heat shrinks, knobs, spares, fishing hook (hey what's that doing here?), soldering wire, flux, tape, crocodile clamps... And probably, close by, there is a long row of immaculate headphones, stock and modded.
Would you make me a good cable and send it to me?
I'm not after something very high end. This is for the porta pros after all. Good as they are, they are a modestly priced headphone so I'm thinking that the cable should reflect that. Good, at a resonable price.
