Thanks and sadly that version is all looks and no function, or at least intermittent function
The wire i've used is 1m of
https://www.hificollective.co.uk/wire/neotech-digital-balanced-cable-nevd-2001.html , with WTB RCA connector which is supposedly rated at 75ohm (which i'm not sure is possible in a connector)
I've just had a look at the manual too, which i next time i'll do before starting, but i'm still not completely clear what they're referring to as their only appears to be one Coax port and do they mean "signal" is attached to the following: "
Coax1 configuration = Tip and sleeve, Coax 2 configuration = Ring and sleeve
These are the 2 configurations i have tried with the mono version.working fine, whereas the stereo version creates the intermittent connection if you twist the plug in the socket.
Sorry i'm probably just being thick!
