jason41987
- Oct 20, 2012
So TRRS is adequate for balancing headphones?
Are you talking n the headphone side or the amp side?Unfortunately mini XLR doesn't fit that well into a lot of existing headsets so another system has to be used. If a 4 conductor TRRS is sufficient then it's a pretty straight forward conversion for a headphone with an existing 3.5mm jack and probably the better solution. Why don't people just use a 4-pole 3.5mm TRRS?
I meant the use of mini XLR, 5-pole phone, mutliple cable connections, etc going to headphones. 3.5mm TRRS for the headphones seems to be the easiest on that end, then terminate the headphone cable into another 4-pole TRRS or mini XLR that can be connected to amps or normal unbalanced outputs with adapters I guess?
On the other end its the normal XLR not mini XLR that is standard for Balanced Amps. you could though have a mini XLR and then have different connectors from here for Full Sized XLR, 1/4 inch or 4.4mm TRRRS depending on where your connecting.
The thing to watch out for with XLR (mini or full size) is the number of pins - the most common XLR jack/plug in use is for mic or line in or out connections (dual mono/stereo, for example on DACs or recording interfaces), and is 3 pin. There are 4 and 5 pin variants. The 4 pin is what you’ll need for a single balanced output and is most common for headphone use.
Look at this thread first post by hakuzen: https://www.head-fi.org/threads/low-end-cheap-generic-otherwise-bang-for-buck-cable-thread.891911/I am wanting to make a set of headphone cables similar to the ursine audio system. I have already sourced the mini XLR connectors for the split, I need to find a source of quality connectors for the rest of it. My current headphones are 6XX and HE-4XX with 2.5mm trs at each ear. also have questions about the recommended wire. I want these to be balanced, My current main amp is a monoprice 788. I need a good XLR 4 pin and Ill probably make an adapter for all the other connectors as well thats the neat part of their system. I have seen the links in the OP and spent some time last night looking but didnt really find much in the wire area. is there a goto 4 conductor wire people like?
ETA, ok I am getting most of what I need to finish from redco. have inc shipping was ridiculous.
canare 4 wire balanced mic cable mini should be good for the main lead, reg balanced mic cable for the split?
ETA 2 damn even redco shipping is crazy.![]()
A question about the PET shielding. One side can work with a variety of diameters underneath it. So say you have a colored cable that you want to see through a black mesh can you use a smaller side PET shield almost opened up to its max diameter and get something closer to a see through or screen effect? I'd like to use an orange cable underneath with sort of a black mesh over top so only half or less of the orange shows through.
