Paladin79
Previously MOT: Cables For Less
yes sir, i recently did the detachable cable mod to them and my ad500xs but the 770s i feel sketchy about because i used the original cabling to do it. So I think im going to use the innards of the w2893 to replace all of the original wiring, including the left to right drivers
Personally I would go with dual inputs on the 770's in case you wanted to use a balanced amp sometime, maybe a 3.5 mm jack or an Hirose jack, separate grounds for left and right channels and you are in business. I modded some California Headphone Company Silverados over to high impedance with separate inputs. (Beyer drivers.) They already had the 3.5 mm jacks in place so there was not a lot of work involved. Modified cans with OCC copper cable on left, standard CHC cans on the right. I will mod them one day as well but just a new cable on them works wonders. You can generally grab them for around $50 in good shape, swap the drivers, drill a couple holes and they are open, high impedance headphones worthy of a Steampunk Bottlehead Crack. (my mods on Crack).
