Sharkhunter
- Jul 15, 2012
24/26/and 28 awg.....AWG stands for American wire gauge, the smaller the number, the larger the wire gauge ergo 28 awg is smaller than 24 awg and would probably be fine in your application. It should cost you less.
Now Litz occ silver plated copper IMHO is mixing terminologies and I am not so sure it exists as such. Litz wire is often used for transformers and often it has an enamel coating on each strand. I have also heard people talk about litz braiding so you may well be using that term.
Personally I try to talk people out of buying silver plated copper unless they just want it for looks. The reasoning behind such wire is, with the skin effect the signal travels on the outside of a given wire and silver is a better conductor therefore they use just a thin layer there. (it might also be used to keep down oxidation but that is another story.) The skin effect usually kicks in at frequencies around 100kilo hertz and you will be listening to a signal that should be at an audible range of about 20 to 20k hertz (if you are lucky) so paying for silver plating makes little audible difference.
You can find Litz wire on ebay and you can find OCC copper, silver, and probably silver plated there as well. Just be a little cautious where you buy it, OCC is a Japanese invention and if you buy it from a Chinese source it makes me wonder about authenticity.
That being said, if you get a chance, try to listen to a decent quality OFC wire and compare it to some OCC copper lets say, and see if you can hear a difference. If when blindfolded you can pick out the OFC compared to the OCC all other things being equal, then by all means buy the OCC. I have the luxury to have at my disposal most types of wire made and in my own testing, it is rare to find someone who can consistently tell a difference.
Thank you.
I found this listing on ebay.
http://www.ebay.com/itm/302383473399
Will this work for making iem cables.?
