john777
- Jun 3, 2013
How the bleeding hell did you take a picture while actively soldering? Just how many hands do you have?!
:eek:
Probably like me he uses his feet as well...
:eek:
:eek:
Adapter cable done!
Which paracord version did you use. I am planning to make a custom cable for the Mr Speaker Aeon.. Just started collecting all info. I was thinking of using 275 Paracord.
I noticed that there is glue in the jacks and connectors of aftermarket cable. Now I am trying to replace the connectors. Is the glue really necessary and what kind of glue is it?
Thanks
Hey there folks! Hoping one of you guys can help me out. Im looking to make or have made a replacement cable for my Klipsch x20i IEMs. They use these idiotic screw-type coaxial SSMCX connectors and I am unable to locate any info or replacement cable on the web. Klipsch said "coming soon" but to be honest they are not even breathing hard yet! lol Any help would be greatly appreciated.
http://www.molex.com/molex/products/family?key=ssmcx&channel=products&pageTitle=Introduction
you might find someone with the Molex SSMCX connectors if you can pin it down to a specific part number. I would think they would be using 75 ohm coaxial cable since 50 ohm is more for RF applications. I have not built with those particular connectors before but often times you would crimp or solder a center pin and crimp a collar ring over the outside braid. This type of procedure is pretty exacting and you have to have the proper size crimp dies. I know of some quality miniature 75 ohm coaxial cable but you have to concern yourself with the outside diameter of the cable and dielectric. Having just looked up your IEM's I do not think this would be a good DIY project. Maybe Klipsch will eventually have a solution cause those are not cheap IEM's.
Tom
Thanks for the reply Tom. Yeah the inline microphone/volume control snags everywhere and the cable is far too short.
