DIY Cable Questions and Comments Thread
Feb 22, 2017 at 8:56 AM Post #6,301 of 10,535
  Thanks for the info and quick reply!
You are most welcome, just let me know what length cable you would like to build and if you will be using a three or four wire braid. If you decide to go with the Rean four pin mini xlrs I talked about, you can get them from Markertek and I posted links earlier.
Tom
Feb 22, 2017 at 6:26 PM Post #6,303 of 10,535
I'm not sure if one of these images have been made or not yet, but here is the pinout for the 4.4mm balanced plug. This is based on the Kimber Kable 4.4mm balanced cable straight from Sony.
Just don't get the need for Sony to do this. Wanted to hear the Z1R's on my gear at a meet but nope because of the cable.
Feb 22, 2017 at 6:41 PM Post #6,304 of 10,535
Yep. That's one of the main reasons I went with the Opus#2 instead of the WM1A. I just didn't want to have to reterminate all my balanced cables. :cool:
Feb 22, 2017 at 6:58 PM Post #6,306 of 10,535
Feb 22, 2017 at 7:06 PM Post #6,307 of 10,535
The WM1Z is what was at the meet and I thought my QP1R was heavy that thing weighed twice as much I bet.
Feb 23, 2017 at 2:10 PM Post #6,309 of 10,535
  Started making a balanced cable for my HE-400i headphones. Here's a picture of a partially finished XLR to 1/4" adapter.
Pretty sweet for my first cable :D
Nice looking cable. A good quality Neutrik connector obviously. Once you take it down to a TRS there is a common ground so I wonder then if such a cable would be considered balanced to unbalanced?  The way the neutriks lock on the cable is really top notch, you never have to worry about the cable coming loose as you might with a small clamp on some connectors.
Feb 23, 2017 at 9:13 PM Post #6,310 of 10,535
Hello all
What would be the best wiring geometry for the 8 core braided cable? I guess B??
Feb 23, 2017 at 9:36 PM Post #6,311 of 10,535
Hello all
Not being a engineer but I would pick A or B as it doesn't put things together but that could be totally wrong . I don't think on a short cable it will make much of a difference.
Feb 23, 2017 at 10:03 PM Post #6,312 of 10,535
I guess Kimber does it up to split in A) way. By the looks of of their web pictures of the cable. They use two colors for each ground and signal wires.
Feb 23, 2017 at 10:10 PM Post #6,313 of 10,535
Doesn't matter what color .
Feb 23, 2017 at 10:12 PM Post #6,314 of 10,535
LOL :p
I know just told it as a guide to examine the y split of the headphone cable!
Feb 23, 2017 at 10:53 PM Post #6,315 of 10,535
How the bleeding hell did you take a picture while actively soldering? Just how many hands do you have?!
:eek:
