jodgey4
- May 2, 2013
This is very confusing for me to understand. So the blue dragon cable is not compatible? I think the stock cable for the ADs is the quad star canare
The conductor itself (quar star, etc.) doesn't matter. I just checked, and the Alpha Dogs appear to use a custom plug at the end, you can buy them off the site though. I just meant, that since on each plug there are four pins, and they are paired together, you could just run another piece of wire between each pair, and then you could run only one back to the main plug. Heck, you don't even have to do that if you don't want, the cans will still get the signal. You can order a pre-built blue dragon cable with Alpha Dog plugs off the Moon Audio site.
