- Feb 1, 2011
Put your multimeter on Ohm
One tip on the tip of the 3.5mm jack (as that is left) the other end on the main centre cable. Should read 0 or near.
Next put the tip on the sleeve of the 3.5mm jack, the other tip on the bare wire that should be ground.
