Originally Posted by parskey /img/forum/go_quote.gif
I was wondering if you guys think it would be better to get j$ pads and wood cups or a new amp or dac? I currently have uDac->LD I+->d2000.
I'd get J$ pads and a new amp/DAC for starters. The amp and DAC you're currently listening through are good beginners amps, but don't get near the potential of these cans. As for what to upgrade to, we'd need your budget.
The J$ pads are a reasonably inexpensive upgrade that makes a substantial improvement in SQ. Tames the bass and enlarges soundstage substantially.
The wood cups are definitely a great upgrade as well, but I wouldn't prioritize it over an amp/DAC upgrade with the low end amp/DAC you're currently using. I'd say the soundstage increase is similar to that of the J$ pads, but the J$ pads change the way the sound is presented in a positive way (blends it together more) whereas the cups just add a little more separation.
The cups basically just enlarge soundstage, give the headphones a fuller, richer sound (and that's coming from D5000 wood cups, it'd probably a quite substantial improvement in musicality over the plastic cups of the D2000), and if you have Mark add damping tames the bass a bit.
But yeah, amp/DAC and J$ pads first, then wood cups later, just because the amp/DAC will be a larger improvement than anything else.
