Dec 30, 2014 at 8:21 AM Post #4,411 of 5,256
Dec 30, 2014 at 6:59 PM Post #4,413 of 5,256
  What are you guys doing about headbands? That part of my D2000 is also wearing out, any mods anyone willing to share would be appreciated.
Martin from Martin Custon does leather headband work but be advised his lead times can be months..................
Putting a Sennheiser HD650 headband pad on will help with comfort and reduce the wear on it.  Applied with a bit of double stick tape, it is a good solution I've put on two of my Denon's.
Jan 2, 2015 at 12:06 PM Post #4,415 of 5,256
Hi,
I don't know too much about Denons, just that they have very good bass. So an advice from you would be useful.
Someone is offering me a pair of D2000 for 200$. Is it a good price?
Currently I own the DT990 Pro for 2 years and I'm in the mood to change them although I like them. How is the D2000 compared to the DT990? Ilisten mostly to Hip Hop, Electronic, Soundtracks.
Thanks in advance for advice.
Jan 2, 2015 at 12:56 PM Post #4,416 of 5,256
  Hi,
$200 for a D2000 is a good price for the current market.
Can't help on the comparison to the DT990, sorry.
Jan 2, 2015 at 1:03 PM Post #4,417 of 5,256
I own both and find them similar with the main difference being the size/dimensions of the soundstage. My D2000's though came modded from ccasper. That and the denon's being closed gives greater isolation
Jan 5, 2015 at 8:57 PM Post #4,419 of 5,256
Th600 is very comparable to D7000 so you could compare it to D7000.
Jan 10, 2015 at 7:16 PM Post #4,420 of 5,256
I sold my Dt990 Pro and am probably keeping the D2000 (I also have Denons D600 which I quite like).
The D2000 has a better bass reproduction and goes lower in frequency than the Dt990 Pro,
It is slightly less airy than the dt990pro in the highs but very good for a (semi) closed headphone. In the mid ramge it is better than the dt990pro - more detail and fortunately not the sibilance (harsh s consonants) of the dt990pro.
Comfort-wise, it is a close call.
200 usd is a good price, you should always be able to sell them again for at least that (provided a good condition).
For easy listening the D600 is sometimes easier on the ears. The D2000 has more highs than the d600 and is more revealing of poorly produced recordings. The D600 also has slightly more bass than the D2000.
Jan 12, 2015 at 9:50 AM Post #4,421 of 5,256
Agreed - good call. I have kept both my DT990 and D2000 - they are a good compliment to one another IMHO. The only other phone I am currently holding onto outside of those two is the Pioneer SE-A1000 as it has a great soundstage and runs pretty well unamped and is very comfortable for long periods of wear.
Jan 12, 2015 at 10:41 AM Post #4,422 of 5,256
I like the combo of Beyer 990 and Denon 2000. Both have their flaws and strengths and seem to compliment each other well depending on what type of music you like. I used to listen to both a lot until I got my custom pair of MS2000's. The ms2000's seem to take all the flaws of the denon 2000, mostly weight, fragile adjustments and recessed mids and fix them. They also don't sweat like the denon 2000's on long listens. The beyer 990's I love the sound but after a while the Grado-esque sound begins to really fatigue.
Jan 15, 2015 at 3:28 AM Post #4,423 of 5,256
finally, my quest for wood cups is over! :)
i am the new owner of these (which i bought off Punit, so they may have appeared in this thread before):
D5000 with Martin Custom Audio Cocobolo Rosewood Extra Deep Cups & Headband Mod, Lawton Audio Angle Pads, and Signal Cable 10ft Silver Resolution Cable with Neutrik 1/4" plug
not the best photo, here are some better ones from Martin's site:
