soundeffect
- Aug 30, 2010
The d2000 definitely has more treble, bigger soundstage, more bass, more fun. I'm with biscuitz.
I've been appreciating my D2000s for ~5 years now and have been looking for a set of earpads on/off for a few months now to replace my well worn ones. Lawton Audio is the easy answer but I'm not impressed with the $99 price tag. Have I missed a good set of pads for the D-series somewhere along the way? I'm interested in gel, or leather, the Beyerdynamics gel 770 are "supposed" to be available in August (not holding my breath). I was surprised at how difficult it is to find a set of 100mm/4" pads, seems like there's gotta be something out there I've missed.
Awesome, the HM5's have been my budget backup if I can't find anything gel or leather under $40-50. Got a lot more to check out now, many thanks
Found a pair of used Beyerdynamic gel pads and they arrived today. They're a bit firmer than I was expecting, and they get a bit warm. They are a nice thickness & no complaints overall, I think they'll keep the d2000's in use for a few more yearsI'll look into covering them with nylon or something to keep the heat down.
Here's some info I've found about possible pads for anyone else unsatisfied with the current options. Make sure to confirm that the application will work yourself.
(The d2000 uses 100mm/4" undercut angled pads, so anything with similar dimensions "should" work)
Lawton Audio
JMoney
Beyeydynamic gel ear seals for dt 770 / 880 / 990
HM5 / Fischer FA-003
T50RP / Shure 840
HE400
dt770 / dt880
dt250 / dt280
JVC ha-rx700 / ha-rx900
ATH-a500 / a700 / a900 / a1000
Sony SA series (sa3k, sa5k etc.)
ad900? w5000
*David Clark aviation gel pads do not fit, (they're ~1/2" too small in diameter, but are very nice pads). They are supposed to fit the m50.
I was surprised at how difficult it was to find angled & leather pads. Guess that's why LA can sell theirs for what they do.
