yavormoskov
- Aug 30, 2013
Maybe I will do the same
I believe it is wired for a balanced connection, I emailed norne audio about a custom cable a wile back and they said it was possible
There's also the oppo pm3 if balanced is a must, I auditioned bout and ended up liking the denons better but the oppo is a great headphone as well
If you can spend 800 then get the T1 gen 1. There is like new one now on Amazon at USD650. If you want to save 300, then get the Denon.
@bellavida I think the pm3 would probably be a better fit for you but try the denon, just remember they require a long burn in to sound there best don't judge them on first listen as they usually sound bass heavy and veiled. The T1's were to sibilant for me with some recordings but I am sensitive to them so take it with a grain of salt.
