chrisr34000
- Jun 13, 2007
I still consider them bright, visible on measurements, too, and compared to other headphones.
But the D9200 treble depends also on the earpads (everything else, too, but treble is a bitch and not all pads will affect the treble).
For instance, these (the leather version, not the protein ones) are very good earpads to start with, even in stock form.
https://www.aliexpress.com/item/4000908305455.html
In addition, if you dare to mod them, they become quite stunning, much better than the original pads, and far cheaper. Kind of different take than the Stax 007 or 009 pads (which are still better), but with these Chinese pads the treble is less of a problem. The mod is the same as with nearly all other pads: trimming the internal foam, all 4 circular edges (so it becomes more of a toroidal form) and some of the height in the back, about 20-25% of the mass. Resewing is not strictly needed, as the leather folds over the foam completely. Attach to the frame with double sided adhesive patches, not with the plastic mounting rings. Worth a try.
What are in your opinion the best earpads to fix the "brightness" of the D9200? The Stax pads? Do they fit without modding?
