The Correlation
Thank you very much for linking these videos, they are indeed interesting. To be honest, I find the only real issue with the 7200 to be some low-level midrange ringing. A finer material could well be the improvement to the sound the 7200 needed.There is a comparison slide inside this video, it was very informative.
So, in essence the D9200 driver seems to be "almost" the same as the D7200 driver - the membrane seems to be similar, eventually the magnetic circuit might be different, I don't know what they mean by a new iteration. The cups are certainly different, the cables too, with the D9200 one gets two cables, and it's made in Japan.
Even if they made a minor tweak on the driver, it might affect the sound just in the right direction and amount to make it worth upgrading. Let's see, but certainly there is less difference between the D9200 and D7200 than between the Fostex TH900 and TH610 (and Massdrop iterations using the TH610 drivers). To start with, I am not sure the Bamboo cups "sound" better than walnut. Maybe it's the cables that make most of the difference. Will see soon, hopefully.
The made in Japan is actually also something important. I have noticed that some inconsistencies exist with current batches of 7200s. For instance, a new pair I purchased a few months ago actually had a really scratchy hinge and the cup fell off. The replacement didn't have that, but it left me weary.
