801evan
Yet you use the hypsos on the OOR. Which brings my point that psu is very important. Otherwise you would use the stock psu.I have to disagree here. I have both the Hypsos/Oor and the A90.
Yes there is a noticeable difference between the combos. But, i still get a fairly good sound signature from my A90 even on my Susvara. It just doesn’t hit as hard and it’s not bad on the stealth either after trying a pair on them yesterday.
Hypsos psu isn't that great either so...I can understand your impressions but what you said isn't conclusive at all.
The small delta you hear between the two also shows it's not all about the amp. The rest of the chain is a bigger factor. Granted, it is also within expectation that the delta is small too between amps to a certain extent. Because one should be focusing on the rest of the chain than obsessing on what amp to use to drive low distortion HPs like the Susvara and the Stealth. And my comment is to debunk that going towards such a trajectory would be sterile. When done properly, it will be smooth and glorious and Topping shouldn't be an example of a good amp due to the weak sauce psu in it.
So you have to make a stand...is there really a noticeable difference with the hypsoor vs the a90 or there isn't?
