ThanatosVI
Do the Lina and/or Bartok also have mapper that the Rossini has?Tbh the soundstage width is not an issue for me, as both the Rossini ( via Mapper change, widening is more drastic than the HM1 even but at the expense of center image definition and it's a different sound altogether) and the HM1 (more subtle than Rossini, but absolutely no impact on imaging, tonality, etc) have options to expand the soundstage to levels of the Ca-1a, Susvara, etc. Even on the Stealth i can get the soundstage to "too wide " levels, so I leave the Rossini on the "narrow but great center image" setting and just use the Hm1 to widen it. No downsides whatsoever.
What I would love from the Expanse is a bit more impact, and a bit more depth. Those are the only 2 things i'm missing from Stealth compared to the Ca-1a (Star 8 and Mitch's filters). Turning the Rossini to 6v instead of 2v into both the HM1 and Oor gives a TON of slam, and i've been listening that way for a while on the Oor, as it just sounded too soft with Stealth, but it does come with some drawbacks. Bass is a bit exaggerated and comes at the cost of clarity in other regions. 2v is a lot more balanced and with better imaging, even though there's a bit less slam. I don't think this is a current/power issue, but maybe 6v is just a bit "too hot" for the amps and causing some distortion. Can't really explain why bass becomes so bloated otherwise.
Sounds like an interesting option
