Hifivoice
- Sep 13, 2007
Absolutely agree with you here. My point is that with moving the headphone around on a jig, you can anticipate on variations already. You can add hair, glasses etc. (off-topic, I already grew through my hair linePositional variation on a test rig may not always match variation across individuals. Some variables (such as clamp force for example, presence of hair, etc.) aren't accounted for, and conversely some of these positions might not be superbly representative of how a cohort of real humans would wear the headphones.
Yeps; the question is if some sort of personal measurement with in-ear microphones, can result in a correcting profile (as a good start), and whether a reference measurement can be defined for that.Indeed and being able to assess how headphones vary across individuals in light of the latter's variation in HRTF is one of the things I'm eagerly waiting to learn more about.
Yes, for instance with a HD660S; here you see that due to the driver being much closer to the ear, you get measurement issues at higher frequencies. In general, I would say that these sort of measurement from 4kHz onwards are getting unreliable due to the wave length of the sound getting close to all the dimension that are present in the measurement space:So you measured this by shoving a UMIK-1 in between the pad and the side of your head ? Did you repeat these measurements with other headphones ?
![HD660.png HD660.png](https://cdn.head-fi.org/a/12028934.png)
Mmm without questioning the method used, that would still result in highly audible differences between them to me.
Be aware that the UMIK-1 measurement is not "Harman corrected", it is only corrected for microphone deviations. The HEQ target curve (which is the call "Harman-inspired") has a tilt from 300Hz onwards, which explains the difference. You cannot compare those measurements 1-1, and you always need to understand the measurement conditions before being able to interpret it.
See here the title from say 200-300Hz to 1kHz from different Harman Targets (also showing they vary a lot over time).
![Harmann.jpg Harmann.jpg](https://cdn.head-fi.org/a/12028936.jpg)
