Thraex
- Jan 7, 2012
Regarding best sound quality and best possible source (24 bit files) streaming to iPad, with iBasso D7 I've obtained a significative sound upgrade changing from iTunes Home Sharing to Logitech Media Server + iPeng player (no need to have a Logitech device to work), the latter is also able to play 24 bit-perfect Flacs and the interface is better than stock iPad music player.
PlugPayer and UPnP server always downsample in the chain to 16 bits.
The D7 sounds better with iPad + CCK + battery powered USB Hubs (note not any USB chargers pas data too, Y split cable eventually needed) than any USB port of a notebook/computer tested, and you've to mess so much with OSs settings to become crazy and it's nearly impossible to have a clean power feeding the USB Dac.
For the same clean power reason which attects sound quality, I've rouled out non battery powered USB Hubs.
With batteries you've also a portable (maybe not pocketable) system.
With iPad, without a portable storage wi-fi device able to 24bit perfect streaming (until now none confirmed working without downsampling), we're still limited by its internal storage capacity or by wi-fi coverage.
Look here if you're really interested in sound quality 24 bit-perfect portable configs with iDevices http://www.head-fi.org/t/625493/ipad-with-24-bit-files-high-storage-capacity-portability-which-configuration-works-without-downsampling#post_8667839 .
