kwatch
- Aug 2, 2012
Can anyone compare D7 Sidewinder to Audioengine D1?
Normaly you can use a powered usb hub to avoid this problem, maybe be you dont have this issue, for what I remember some persons just receive a warning and can use the DAC normally. I don't have this problem on my "old" laptop.
d7 good match for ultrasone pro 900s (40 ohm)? read somewhere ibasso sounds good with ultrasones. anyone confirm/deny? ty
Hey guys, sorry to bump it up, but i was thinking about getting the D7 as my first dac.
But i've been reading the posts, and it seems some notebooks have some problems with it, mainly with delivering enough power through USB. I don't have a desktop anymore, so i'm kinda worried it won't work at all.. I also don't have any USB 3.0 on my notebook(which usually are able to drive more power...)
any thoughts/ideas?
On the macbooks it gives a message when you first turn on the D7, but it doesn't interfere with the units performance. Actually I've used my D7 on one port, while charging and using my iphone as a mobile hotspot on the other. No problems. I think it creates a temporary current surge when you first turn it on. Maybe it's charging the capacitors?
Crap, I broke my volume knob... now I've only got a stick lol
Do you mean the knob came off, or did it actually break? If it just came off there is allen screw that just needs to be tightened.
I connecting the D7 to my iPad 2 and iPhone 4S (jailbroken with CameraConnector installed) today using the CCK and a powered USB hub. While it worked, it was different from other DACs I've tried, namely the Nuforce uDAC and Headstage/Headphonia USB DAC cable (new version). Normally the volume is controlled by the external DAC/AMP setup, but with the D7, the iPad maintains control of the volume (volume slider in music app) and turning the volume knob does on the D7 nothing. This happens with both the iPad 2 and iPhone 4S. I was wondering if anyone could comment on this.
