Pretardo
The R6 pro has the slight edge on the R5 when it comes to the highs. In comparison, the R5 sounds a bit veiled. The screen on the R5 is a little small and it can be hard to type on it as well as get precise touch controls with crowded UIs. The R5 benefits from having a solid handle on RFI on both the 3.5mm and 4.4mm connections. This is something that the R6 pro doesn’t do.how do u find R6 Pro vs R5?
i too was impressed w R6 Pro Alu
The R6 pro can handle the first unfold on MQA files (88.2 KHz) where as the R5 does a full unfold out to 320 KHz.
hope that helps you make a decision.
