Creative Super X-Fi headphone holography
post-14906763
Post #526 of 888
Richter Di
Germany
Germany
Age
54
Website
pilates-powers.de
post-14908497
Post #527 of 888
eliwankenobi
Im confused.. You are going to plug the Sxfi into the THX amp ? What do you mean use the Sxfi as source.
That is the idea, yes. But perhaps calling the Sxfi a “source” was not correct. The idea is PC -> Sxfi amp -> Thx amp.
post-14908565
Post #528 of 888
Sentenery
Melbourne
Melbourne
I'm using the superxfi with Kodi but unsure of the settings to make Kodi
output 7.1. It shows up as SXFI AMP - Analog and SXFI AMP - SPDIF
With the Analog option when I choose 7.1 there's no sound, with the
SPDIF option there's no 7.1 option. Sound comes out but I can't tell if it's
true 7.1 or upconverted stereo.
What are your settings?
post-14911290
Post #529 of 888
Moebiushaydn
I purchased the SXFI AIR today and I must be doing something wrong, because it sounds abysmal with Super X-Fi turned on. Instead of improving the spatial qualities of the audio, it seems to squash everything into a narrower, more confined space. And it adds an obnoxious amount of reverb that is extremely noticeable when watching movies, as though the speech was recorded in tiny rooms with metal walls.
Suspect something may have gone awry during the 'personalisation'/head mapping phase. Has anyone experienced a dramatic difference just by performing a new round of head mapping?
post-14911297
Post #530 of 888
eliwankenobi
something that helped me was to rescan my head. First time I did it doing a selfie. Second time I asked someone to take the picture and center it carefully and it was much better the second time around. Hope that helps
post-14911312
Post #531 of 888
obiwon
usa
usa
Any chance u have the air connected to the amp creating double SXFI? I did that and the sound was too much. Once I took out the amp it was great.
post-14911331
Post #532 of 888
Moebiushaydn
Thanks for the quick and helpful replies. I performed the head mapping with the help of someone and made sure it was done in good lighting. Re: double amping, nope—have tried both Bluetooth and USB connections. Both sounded equally terrible... unlistenable.
Edit: What I’ll do is attempt the head mapping again. Hopefully something changes.
post-14911351
Post #533 of 888
obiwon
usa
usa
then probably a defective unit. i would contact their customer support. they were really responsive for me.
post-14911360
Post #534 of 888
Richter Di
Germany
Germany
Age
54
Website
pilates-powers.de
something that helped me was to rescan my head. First time I did it doing a selfie. The second time I asked someone to take the picture and center it carefully and it was much better the second time around. Hope that helps
Like @eliwankenobi I did the first round myself. When I got the help of a second person, we did several re-shoots careful examining the way SXFI created a meaningful grid over my ears. And yes, when I listened to my first go and the second one, there was quite a difference.
Reactions: eliwankenobi
post-14912949
Post #535 of 888
Moebiushaydn
I've performed a new round of head mapping with the help of a colleague who also owns the AIR. And sadly, nothing much has changed. I guess the SXFI effect just doesn't sit well with me. Instead of experiencing the purported expansiveness of sound, I get a strong sense of claustrophobia. The only saving grace is that the headphone is somewhat decent with SXFI turned off.
post-14912977
Post #536 of 888
Cevisi
Germany
Germany
I dont like the sxfi for music but its mighty in films or games try it
post-14913021
Post #538 of 888
Cevisi
Germany
Germany
Did you try whit a different headphone ? I use headmapping whit the casual headphome pre set on flat eq whit my dt 770 250ohm and its alot better then dolby atoms
post-14913028
Post #539 of 888
Moebiushaydn
Unfortunately, I’m using the SXFI Air and not the amp, so changing out headphones isn’t an option.
post-14913057
Post #540 of 888
Radical_53
I had the same issues with the amp. Instead of feeling spacious I only had extreme reverb and distortion.
I tried it back and forth and never found a setting that I really liked.
I’ll wait a while and check back where they might go with this tech.
