Nov 14, 2012 at 3:00 AM Post #1,321 of 12,437
Hi everybody.  Just finished my first Crack build and plugged in my DT880/600's.
Holy crap does this thing sound good.
That was my initial reaction as well.  Even in stock form, the crack is surprisingly detailed, punchy and dynamic for an OTL tube amp, and it only gets better with tweaks.  You have to love those rare moments in life when the reality of a product actually surpasses high expectations.
In any event, congrats and welcome aboard!
Nov 14, 2012 at 11:08 AM Post #1,322 of 12,437
Thanks everybody for the comments.
I used Minwax stain in the Ebony color for the base.  The alder wood they send you for the base is really nice so I hated to make it so dark but I just made a headboard for my wife where I used the same stain and it came out looking really, really good.  My base still doesn't have any polyurethane on it (I was too excited to finish the amp to do that part) and when you put that on, it lightens things up noticeably but it still has that nice dark wood look.  My speakers are finished in a beautiful dark African wenge veneer and I'm hoping to end up with something like that...
...when I can stop listening to this stupid thing!  Seriously...[insert cheesy "addicted to Crack" line here].
Nov 14, 2012 at 11:10 AM Post #1,323 of 12,437
I was shocked that I put the thing together correctly, let alone that it makes such amazing music.  It's enough to make you into one of those motivational If-I-Can-Do-It-Anybody-Can people.
Nov 14, 2012 at 1:58 PM Post #1,324 of 12,437
I really like the look of the copper hammertone paint on mine. I tried to take some pictures, but I just can't capture the paint texture.
Nov 24, 2012 at 6:51 PM Post #1,326 of 12,437
Hi Guys,
I have read through some pages here and am leaning toward trying this AMP. I am not 100% Confident I can build it, but hopefully if I get stuck I can get some help.
I have some questions if someone wouldn't mind;
1) What are the dimensions of this and the weight please?
2) What is the power supply? I am from NZ and we have 240v, do I need to specify at time of ordering?
3) I am thinking of pairing this amp with the O2 Odac, will this be OK? What connection will run between the ODAC and BHCA?
4) I am fairly close to my budget, and I have read the speed-ball upgrade is worthwhile, I'll be pairing this with my HD650's
5) I already have an Asus Xonar STX, which is apparently a capable Dac/AMP, is it reasonable to assume the BHCA will be a reasonably noticeable upgrade? I have just been conversing with someone who has the STX and the Dot III and they said listening they thought the Dot III was better, but in a blind test they couldn't pick them apart from the STX. I am concerned about spending $400 and not getting a noticeable improvement.
6) Which parts are most likely to get damaged in assembly, and should I order spares? I guess I am mostly concerned about parts getting too hot during soldering, and secondly damage caused by mis-assembly and having to wait weeks for replacements.
7) I was thinking about doing the wood in a black finish and polishing the metal to a high shine, anyone have any experience with this and recommend a method of it?
8) Anyone know of any other assemblies other than the Wooden Box?
Thanks for your time.
Nov 26, 2012 at 11:01 AM Post #1,327 of 12,437
Hi Guys,
About 11.5" long x 7.5" w x 9" high (with tallish tubes). Weight is about 5 lbs.
You need to specify 240V at the time of ordering.
That will be just fine. You will need a 3.5mm stereo to RCA stereo cable. Something like this:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021817&p_id=9767
I don't think the speedball is a required upgrade. I'd wait - you can always add it in later.
An OTL Tube amp like the Crack does sound different to me (and I can pick it out against solid states in a blind test). Improvement may not be the right word - I like the sound. But I don't know if I could say it is better or worse, it is different. YMMV.
It's a pretty simple build, I don't think you have too much to worry about. I expect the most fragile pieces would be the Diodes (LEDs in the input tube assembly, and those in the power supply).
Nov 27, 2012 at 1:14 AM Post #1,328 of 12,437
Hey guys, I just bought my Crack amp today with speedball, bottlehead's 15% off for Cyber Monday was too tempting. Not to mention the fact that I got an extra 10% off buying with a friend.
Now, any recommendations for boutique film capacitators to build inside? I'm thinking Mundorf Supreme and perhaps some Obligato Gold
Nov 27, 2012 at 9:17 AM Post #1,330 of 12,437
I was going to jump on cyber monday sale as well...but I wasn't sure about building one myself  (don't want to solder etc... I'm just lazy
I've been thinking about trying some tube amps with my HD 800's that should be coming soon. I've been seeing that the Crack is something of a giant killer? Is this the tube amp that I should get for under $1k if I want to try the tube sound?
Also, what happened to the Smack? o_o
Nov 27, 2012 at 2:37 PM Post #1,331 of 12,437
From what I understood the Smack might come back but it was run to the ground (stock) mainly due to having the S.E.X which covered that range of headphone impedance. The SEX also drives speakers which made it better value at the same price point.
I guess it (the Smack) became too niche for the store. I enquired into modding the Crack to run High impedance cans - the cost would shift the unit to the SEX level (which is what the Smack was, from whati understand).
I got the Quickie per-amp on the Cyber Monday sale.
Wormwood
Nov 27, 2012 at 2:48 PM Post #1,332 of 12,437
The Crack is designed for high impedance cans, >120 ohm if I remember correctly.  It works poorly with low impedance cans.
