Whether TS 5998 and WE 421A are the same was a huge debate.
Normally if 2 tubes possess the same innards in any other types of tubes, they would always be considered the same tube - one being the original and the other being the rebrand of course. But some people just can't treat TS 5998 / WE421A the same way, which is pretty weird!
The biggest "fact" that those "not-the-same-tube" believers often cite is that on tube specs datasheets WE421A has transconductance of 20,000 uMhos vs TS5998 only 14,000 uMhos. So they think the 2 are different tubes because they have different transconductances. But what they do not know is that these different transconductances were obtained under different plate voltages and grid voltages, if WE421A and TS5998 were tested under the same plate voltage and grid voltage, they will have the same measured transconductance. And I don't blame those believers, as most of them has little knowledge on how testers work and how transconductances are measured if at all.
Some people say the 2 sound the same, while others say WE421A sounds better. Well, this is quite subjective, and people's opinions are often biased by the prices. It's quite psychological, but it is true. People tend to think the expensive tubes sound better even if they were hearing the same tube oftentimes. This psychological effect can be eliminated by a double-blind test, but in practice few people were able to do a double-blind test.
I used to be 90% sure that WE421A and TS5998 are the same tube (because I only heard subjective reviews with few concrete data). Until recently after spending weeks researching how testers work and their datasheets I'veI become 100% sure that WE421A and TS5998 tube are the same tube.
Data/Facts:
On the military TV-7 tester datasheet, there is one entry for TS5998 and one entry for WE421A. I compared the 2 entries, they are the SAME! So they are using the exactly the same settings and exactly the same plate voltage and grid voltage to test the 2 tubes on TV-7, and the minimum good value of 40 is also the same for both tubes (side note: minimum good value is normally 1 Standard Deviation away from the 100% new, so it is often set at 65% of 100% new on various testers). This proves that the biggest "fact" those "not-the-same-tube" believers hold is WRONG. If TS5998 and WE421A are tested under the same plate voltage and grid voltage, they will have exactly the same transconductance as per the military TV-7 datasheet. Had the WE421A come with a much higher transconductance than TS5998, its minimum good value would have been much higher than 40, but WE421A and TS5998 just have the same minimum good value of 40 if they are tested under the same plate voltage and grid voltage on TV-7. On their datasheets WE421A has a higher transconductance of 20k Mhos (vs 14k Mhos on TS5998), that's only because WE421A was tested with higher plate and grid voltages (i.e. more positive voltage on the plate and less negative voltage on the grid so that the current flow between cathode and plate will become much larger and measured transconductance will be much higher). But if we apply the same plate voltage and grid voltage on these 2 tubes, they will have the same measured transconductance as proved by the military TV-7 datasheets. (side note on the U.S. military TV-7 tube tester: it is for use in battle fields, so accuracy and reliability is of top priority. The datasheets for TV-7 has to be certified by tube and tube tester experts. So I trust what the TV-7 datasheets tell me). Other testers say the same thing, like the 752A tester also has the same test settings and minimum good value for the 2 tubes.
While I do trust our tube and tube amp expert
@Skylab 's opinion that WE421 and TS5998 are the same tube and sound the same to him (side note: Rob aka
@Skylab did lots of great professional grade reviews on tube amps and tubes, and has a gigantic collection of NOS tubes - see pic below), I am more of a scientific person, I always try to be as objective/unbiased as possible, so I'd rather trust data/facts than people's subjective and often money-biased opinions, but what I found through data/facts also prove WE421A and TS5998 are the same tube. Both tubes had some small variations over the years, but they are essentially the SAME tube, both designed by Western Electric and manufactured by Tung Sol / Chatham.
PS:
@Skylab , if you mind me posting the pic that you posted long time ago, let me know, I will delete it.
