It all depends. People's gears / music genres / sound preferences / ... all come into play when choosing tubes.
I know @DenverW and @BobMonkhouse here prefer 12AU7 to 6SN7 on their Cracks.
Its true, but I have some caveats. I've found some pretty big swings in quality of certain 12au7. The bottom of the barrel 12au7 are some of my least favorite tubes overall, while the top end are my absolute most loved. I'd say after having tested many 6sn7, 12au7, and other types with adapters that I prefer the mid range cost 6sn7 over many if not most of the 12au7. My current top 5 input tubes are:
1. amperex welded plate 45 degree 1940's d getter 12au7
2. 1940's victor rca 12au7 (can you believe it? an rca?! The very old 1940's are a different beast)
3. CV6 mullard black plate (with adaper)
4. Siemens silver plate 12au7
5. CBS/Hytron E1148
So 3 of my top 5 are 12au7, and the other two are frankentubes. My favorite 6sn7 is the 3 hole sylvania 'bad boy.' I will mention that i've yet to hear both the tung sol round plate 6sn7 and the telefunken ecc802s. Just too price prohibitive.
As far as using lower impedance headphones with the crack, its my understanding that there will be bass roll off depending on the impedance of the headphone. So I think its certainly possible to listen to lower impedance headphones on the crack, but when you hit a certain song or type of music it will be more apparent.
@ bagwell359 I have an amperex e80cc, and I think the tube has great potential, but I'm too lazy to change the resistors to get the crack to work optimally with it. I was just too into trying other tubes to limit myself to either 12bh7 or e80cc types. The amperex is a rich sounding tube (to me, everything is imho!) that had great spaciousness. Airy rich; I like it a lot. As long as you don't pair it with anything syrupy it will work well. 5998, rca 6as7g, tung sol 6080, 421a...they all worked well. I would say that without that resistor mod the e80cc just didnt beat out the tubes the crack is optimized for. I'd like to one day make a three way switch for 12au7 type/12bh7/e80cc. I've read a bit about one or two others that have done this, but the skill level/effort level is above me right now .
On a side note, I'm having to modify the base of my crack. The kzk 100uf caps were just too big. Luckily, my next door neighbor is a wood worker. SCORE!
