Quadfather
Looks amazing Nice set up you got there
Thanks. I am glad I took the OTL plunge.
You are most kind Bloodhawk, if you ever want to add patina to copper I can teach you that pretty easily. The process takes 24 hours or less but actual work time might be ten minutes or less. Here is a lighter blue patina I added to another copper plate. You can go more towards dark blue or green depending on the salt and liquid combination.
Thanks for the comments. It's so beautiful.That is one of the reasons I offered to teach.
I either do this outdoors or in a shed on the back of my property in the winter. If I ever have questions I turn to my daughter-in-law. Her PhD is in chemistry. I am also used to dealing with ROHS compliance, etc.; even when soldering with 60/40 solder I warn employees that lead is a cumulative poison.
I really do not understand tubes and electronics. I have had more listening time on this tube amp with the new Tung Sol 5998 and Mullard CV4003 tubes, and all of the sudden the bass is starting to really slam hard and go way lower. I like it.
You words worth much more than other expert's on this forum.
Congratulations!
Very nice. I plan to compare the Mullard CV4003 to the Amperex Bugle Boy in this amp. Won't bother with anything else and the only power tube I will be using is a NOS Tung Sol 5998.
I finally bit the bullet and got myself a Tung Sol 5998 tube, paired with a Sylvania 6SN7 input tube. I should have gotten it months ago - the dynamics have certainly changed for the better - it's also dead-silent now compared to the noisy RCA 6AS7G's I took a punt on via eBay a while ago. It's perfection.I really do not understand tubes and electronics. I have had more listening time on this tube amp with the new Tung Sol 5998 and Mullard CV4003 tubes, and all of the sudden the bass is starting to really slam hard and go way lower. I like it.
I'm not electrically-minded enough to understand the impact (if any?) that the Crack's relatively high output impedance may have on performance downstream when using as a pre-amp - is there anything to be mindful of?I have used the Crack as a preamp as well with great results. I went so far as to install RCA outputs in a couple Cracks I built just for that purpose.
Would that just involve linking the L/R wiring upstream from the headphone-out + a shared ground to 2 x RCA outputs? Do any resistors need to be added?I have used the Crack as a preamp as well with great results. I went so far as to install RCA outputs in a couple Cracks I built just for that purpose.
