Crack;Bottlehead OTL
Jun 14, 2018 at 12:49 PM Post #9,271 of 11,214
bloodhawk
Formerly known as ViKiD(TM)
Jun 14, 2018 at 1:00 PM Post #9,272 of 11,214
Paladin79
Member of the Trade: Cables For Less
Indiana
You are most kind Bloodhawk, if you ever want to add patina to copper I can teach you that pretty easily. The process takes 24 hours or less but actual work time might be ten minutes or less. IMG_2280.JPG Here is a lighter blue patina I added to another copper plate. You can go more towards dark blue or green depending on the salt and liquid combination.
Jun 14, 2018 at 1:05 PM Post #9,273 of 11,214
bloodhawk
You are most kind Bloodhawk, if you ever want to add patina to copper I can teach you that pretty easily. The process takes 24 hours or less but actual work time might be ten minutes or less. Here is a lighter blue patina I added to another copper plate. You can go more towards dark blue or green depending on the salt and liquid combination.
Damn that looks awesome!
I might do a LTP build for my dad in a few months, once im settled down again and will definitely send a few questions your way :)
Jun 14, 2018 at 1:08 PM Post #9,274 of 11,214
Paladin79
Indiana
Not a problem, here are a couple other things I am playing around with.coaster amps.jpg copper coaster.jpg
Jun 14, 2018 at 6:09 PM Post #9,275 of 11,214
Allanmarcus
New Mexico
I gave one away, asked kit cost for another, and won a bet by building one but it had nothing to do with selling on Headfi. My current builds are all Class A solid state and some round hybrid amps. I will try to mount a round amp inside a scotch bottle. I like a challenge, this 8 ball will be easy in comparison.
A spherical amp has the potential to be "rolled off". Could be a problem
Jun 14, 2018 at 6:19 PM Post #9,276 of 11,214
Paladin79
Indiana
Unless the bottom is flat, which it is. I was in a hurry and just said 8 ball, that is a magic 8 ball child's toy, cost $6 with shipping from Amazon Prime. The board fits in it like it was made for it, dumb luck.
It took me over an hour to get it open. Picture a knife blade and large rubber mallet. They are well sealed to protect small children I would think.
Jun 14, 2018 at 7:24 PM Post #9,277 of 11,214
Quadfather
Illinois
0614181819_Film3.jpg 0613182126_Film3.jpg Loving the CV4003 so far. And the first picture is my glowing, hot crack! LOL. Bottlehead makes it so easy to sound dirty on the internet.
Jun 14, 2018 at 8:05 PM Post #9,279 of 11,214
Quadfather
Illinois
Jun 14, 2018 at 9:11 PM Post #9,281 of 11,214
Quadfather
Illinois
Yup!
Glad you are loving the amp and glass!
My 5998 hasn't even got to me in the mail, so it's only going to get better. I was close to selling it, and then I thought hey let's try changing the tubes and it may sound more to my liking... So glad I changed some tubes out. I really didn't think an output tube would have such a big impact.
Jun 15, 2018 at 6:27 PM Post #9,282 of 11,214
Quadfather
Illinois
OH, HELL YEAH!!!!!!!!!!!!
Jun 15, 2018 at 6:35 PM Post #9,283 of 11,214
bloodhawk
Isn't it a massive step up form the standard
power tubes ? :D
I love the 5998/421A and the 7236's in my amps and love chnag8ng between them every now and then.
But the 5998's are the most balanced of them all.
Jun 15, 2018 at 6:46 PM Post #9,284 of 11,214
Quadfather
Illinois
power tubes ? :D
So far I am in love with the 5998 / 4003 combination. Sounds very holographic and gives it that gooey tube sound. The 4003 refines the upper end and of course the mid-range is liquid and holographic as well. I may order back up tubes once I can afford it to keep in the safe.
