vintinfinity
Just took out the Speedball from the Crack. Threw the stock resistors back in and while I was worried about the bass seeming to be less after the speedball, it sounds fine on W9 by Nicola Ratti, just a bit less controlled. I did gain back the sweet reverb and echo in regards to the vocals on songs like Hello - by Adele. For me, the speedball was so forward that it was a little too intense and was more fatiging than the stock circuit.
I was having a microphonics issue with a 12BH7 I put in there with the speedball, but I'm not sure if it was the circuit itself or the tube. The ebay seller thought the higher gain on the BH7 was causing it, but I'm not sure if that's true. Other people have reported using 12BH7 without microphonics. idk. Anyone have input on that? He was perhaps offering a replacement 12BH7 but seemed to back off that notion when he found out the stock tube is the 12au7.
