ClintonL
- Mar 15, 2012
I've got a mod for 12bh7's. Not sure to grab one of them or a electro harmonix 12au7
Just got my (used, built by a first timer and failed install pulled out to the side) basket case speedball boards installed and working. My pop is an old retired tech and he helped me trouble shoot it (he found a broken LED lead on one of the A and B boards, which we fixed) Then installed everything in the Crack amp.
One wire was misplaced to the G instead of the O on the speedball board so I was disappointed it didn't work at first, but I had a beer, cooled off and dove back in and found it myself. Couple touches of the soldering iron and it's working great.
Feels good. I got a hell of a deal on it. Now I just need to get a 6sn7 adapter for the vintage RCA and Sylvania and GE tubes I have of that variety, a 12bh7 or two, and install my ALPS pot and maybe eventually some film cap upgrades, and possibly a choke if it's that big of a deal. Plus get some sanding paper and tung oil for the base.
Finally have my end game set up with the HD650s I'm using with it.
Cheers!
How about a picture after finished applied?
Finished speedball upgrade last night. Voltage checks after small board install weren't right and it took me couple of days to figure it out. Turns out the stock 12au7 was bad. I dropped a Gold Lion in and everything checked out fine. Speedball was well worth it. Am feeding the Crack with the Bifrost Multibit and it sings like an angel.
Can't turn the volume past 10 o'clock or it's to loud which concern me as it use to sit at about 11 o'clock...
Am going to have to have a little shoot out between the Crack + HD600 and the Lyr2 + HE 560 later today but for now ... am just layin' back with a big old grin.
Did a comparison between my BH Crack + HD-650 vs Lyr2 + HE-560, both sound really good but it depends on the music to make me prefer one over the other. Would like to hear what your thoughts are on your shoot out.
EDIT: Spend the day with the Crack and and the HD800's. Also bounced back and forth between the HDVA600 and the Crack w/Speedball. Crack out classes the HD600, there is more exposed through the Amp than the headphones know what to do with. The crack vs the hdva left me feeling the above statements are even more true. I feel like the Crack was on par with the lyr2 detail wise, but not the hdva. The signature was not flat but presented more flat with the HD800 and was much tighter throughout the frequency spectrum than it was the HD600. The organic vs mineral was also more apparent, especially when it came to percussion instruments. Imagine, if you would, a drumstick striking a drum head... a well mic'd drum reveals things you'd never hear across the room... the hdva gives you the experience of the mic... the Crack gives you the experience of being in the room.
