Maxhawk
- Nov 3, 2005
That's just for the speedball upgrade right?
I would feel at ease if there was a simple video of it being added with instructions & tips.
I seen a few videos for assembling the Bottlehead, but nothing on the speedball upgrade.
Yes that's just for the speedball. When you purchase the speedball kit, it comes with a nice PDF installation guide with lots of detailed pictures and instructions showing you how to build the boards and make the connections. You do need to be good with a soldering iron, and the more difficult part I think will be removal of installed resistors and wires since they'll likely be wrapped around eyelets and soldered in place. Solder wick will help remove the solder but you have to be careful not to overheat things.
Here's are a couple of random image I found on the internet, one original and one with the speedball kit installed:
