Loquah
Have you done all of them, or just the ones near the noisy tube?
Wow. That's weird then. I wonder what's causing it!?
Sounds like a case to take over to the Bottlehead Forum where the experts who designed it are.
I already use both forums for it. Never know in which forum some great info jumps out.
Sounds like the tube is resonating for some reason, possibly loose construction in the tube. Did you say that you can hear it in the audio? This will sound weird, but I've had luck turning my WA3 on its side and let the tube get good and hot, then rap it with the eraser end of a pencil and sometimes they stop whining. Then turn it off and let it cool sideways. It's a last resort, and some will say crazy, but I've silenced a number of tubes this way.....I've also killed one. The tube might arc when you hit it, so use a pair of cheesy headphones and not your good ones.
How many 5998 make the noise? I thought your 6AS7 was quiet.....
I thought it was quiet too, but yesterday after 1 hour of listening the noise came in. It is lower frequency than with 5998, but it is still there, and it goes quiet when tapped like with the 5998. Previously both tubes were perfectly silent. Less than a month ago that noise appeared for the first time. But if both tubes react the same, then the tube(s) should not be the cause. That squeal does not get louder with volume. I change out electrolytic caps today and see if anything changes.
Now the speedball...
